Old 03-14-2011, 04:45 PM   #1
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Question Advantages of the 73-87 front suspension?
Besides the 5 lug conversion, what are the other advantages of swapping to the 73-87 front suspension?
Also, is it better to convert the original 12 bolt to 5 lug or swap in a 10 bolt out of the 73-87 chassis?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 03-14-2011, 08:15 PM   #2
SCOTI
SCOTI's Avatar
Re: Advantages of the 73-87 front suspension?
Advantages or differences depending on your perspective....
73-87's are easier to source parts for.
73-87's are cheaper to source parts for.
The thicker rubber of the 73-87 bushings isolate the chassis from noise/vibration better then the earlier pre-73 rubber-lined steel bushings.
As far as the rear housing, if you swap in a 10-bolt from a 73-87, you still have axles w/@ best 24yrs of service life (bearing wear), you have to do the labor for the swap, plus you'll possibly have to remove & fabricate new bracketry. Swapping in conversion axles is by far the better choice unless your rear housing is trashed & someone is offering a fresh 10-bolt.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-14-2011, 11:35 PM   #3
C10_ustacould
All good points. Thanks for the info. What about rear brakes? Will 73-87 brakes bolt up to the 12 bolt? If you are going to have the axles out anyway, might as well change the backing plate if it would work. That would make servicing the rear brakes just as easy.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-14-2011, 11:52 PM   #4
SCOTI
SCOTI's Avatar
Yes they will also interchange. From the ones I've messed with, there wasn't much (if any) difference unless swapping the HD rear brake set-up. The backing plate is different for the HD set-up. When I've done 5-lug convesions, I bought parts for a 71-72 truck & used the early 6-lug drum backing plate w/o issue. The only 'custom' parts were the 5-lug axles; everything else was 71-72 spec'd.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-18-2011, 03:59 PM   #5
OJ1988
Just a car guy
OJ1988's Avatar
I swapped to 73-87 front, but went with cpp 6 lug rotors so I did not have to touch the rear.
Things I noticed, A Arms are physiclly bigger. Bushings are bigger ( I swapped in poly urathane), ball joints are bigger, tie rods are bigger....
you get the point.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 03-18-2011, 05:33 PM   #6
SCOTI
SCOTI's Avatar
you get the point.
Disc brake parts are 'heavier duty' vs. drum stuff.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-22-2011, 01:55 PM   #7
kieth
kieth's Avatar
One thing to watch for is the 73-87 Pickup and 73-91 suburban---the track is wider, so watch your front fender clearances, I think 3/4" per side so a total of 1.5" wider.
kieth is offline   Reply With Quote
