Old 03-22-2011, 06:37 PM   #976
VA72C10
VA72C10
VA72C10's Avatar
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Here you go....
Old 03-22-2011, 06:42 PM   #977
67cheby
67cheby
67cheby's Avatar
wow...very nice guideline !!
67cheby is offline   Reply With Quote
Old 03-22-2011, 06:43 PM   #978
VA72C10
VA72C10
VA72C10's Avatar
It only took me 3 tries to put the right numbers on
Old 03-22-2011, 06:53 PM   #979
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
Drew,
Having done a complete rebuild of my '67 Corvette, I have an immense appreciation for your creativity, craftsmanship and amazing speed.
That truck will be a real beauty and a wonderful "family" vehicle. Well done hardly seems to be adequate praise.
www.67HEAVEN.com
2004 Z71 Tahoe 4x4 5.3L (factory white monochrome theme)
1989 Silverado K1500 4x4 5.7L sportside (white monochrome theme)
1967 Belair 2-door-post (project)
1967 Corvette 427/435 coupe (now 502/502 red road warrior)
67HEAVEN is offline   Reply With Quote
Old 03-22-2011, 07:45 PM   #980
thor
thor's Avatar
Originally Posted by VA72C10 View Post
Here you go....
Nice! And, thank you! Great detail!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 03-22-2011, 07:55 PM   #981
classicchev
classicchev's Avatar
Originally Posted by drewskiren View Post
It's really all just trick photography.
I think it may be the patented cross draft spray booth
I have the same one, and its perfect for what I do, and no complaints from any neighbours yet, knock on wood.
Looking good.
Darren
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 03-22-2011, 07:59 PM   #982
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
How far is ar from tn hahhahahha Paint looks killer and reminds me of kevins low buk build..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 03-22-2011, 08:14 PM   #983
jugernot
Life, Be In It.....
jugernot's Avatar
I have seen this thread many times but never opened it till now. That is quite a build and will be a sweet ride. Nice work
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 03-22-2011, 08:41 PM   #984
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
DANG, I'm gone to the soccer fields for 2 hours and there are 10 posts!
Thanks so much for the diagram!!! Next time though, could you color code each screw hole for me??????
I just checked another door and my bed front and both are 13.5 inches from the center of the upper trim hole down to the body line (a 13.5 inch white stripe). Is this correct too? I think this works out the same also on the rear of the fender. I don't want to paint it twice!!!
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 03-22-2011, 10:19 PM   #985
drewskiren
drewskiren's Avatar
I got the hood done tonight, and all was going well until I had a couple of critters decide to join in the fun. I got one out with the tweezers, but the other was just a little guy. He got painted over on the 4th coat, but that one I laid on a little too heavy and created a signature on the front edge. Friday I will wet sand the run and my little friend's paw prints and shoot one last heavy - but run free- coat and call it done. While I am wet sanding with 400 grit I will use my block and knock down the orange peel so the last coat will turn out really flat. My goal all over will be like the 4th pic where you can almost read the writing on the fluorescent bulbs. If I can't get there by painting I can always buff it there.
Drew
Old 03-22-2011, 10:30 PM   #986
Flint70step
Flint70step's Avatar
Wow man, you got that last coat pretty flat.You can almost read the lettering on the light bulb.After seeing this build,it has severely diminished my fear of doing my own paint.Not only would it save me truck loads of cash, but the satisfaction of doing it yourself and doing it well has a lot more value than paying some one to do it.I think you deserve truck of the year even before its done.Nice work Drew.Yall be good
Flint70step is offline   Reply With Quote
Old 03-22-2011, 10:33 PM   #987
VA72C10
VA72C10
VA72C10's Avatar
I have 16" between center of the holes on the rear of my cab. And same between the paint on my fenders.
Not sure of the paint line as mine is all white
Maybe someone else will know where the break should be (center of holes or top of trim)
Old 03-22-2011, 10:37 PM   #988
drewskiren
drewskiren's Avatar
THAT'S what I'm talking about!!!! I'm telling you guys, it's not that impossible. It is certainly worth trying on a spare hood and seeing what you can do. Buy a how to video, talk to the local paint supply house, ask me, whatever!
Truck of the month would be awesome (not so sure about year), but the category would have to be "in process".
Drew
Old 03-22-2011, 10:39 PM   #989
drewskiren
drewskiren's Avatar
I got 13.5 to the body line, I don't have any parts with trim holes top and bottom to measure between the holes.
Drew
Old 03-23-2011, 12:49 PM   #990
Rumble
I have wanted to do one of these for years, not enough knowledge or time, great attention to detail
i ended up with this as my project, still workin on it
it started out as a 1 ton long bed dually, i should be gettin from paint shop today ( stayed with factory white)
Rumble is offline   Reply With Quote
Old 03-23-2011, 01:06 PM   #991
mrchrishill
mrchrishill's Avatar
Lookin' good Drewski. What are you going to do for a dash now that you crammed that full AC into it?
mrchrishill is offline   Reply With Quote
Old 03-23-2011, 01:43 PM   #992
jbclassix
Junk Yartist
jbclassix's Avatar
Drew always attracts new members!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-23-2011, 04:38 PM   #993
drewskiren
drewskiren's Avatar
Can I get a referral discount on my membership???
Drew
Old 03-24-2011, 12:33 AM   #994
drewskiren
drewskiren's Avatar
Funny you should ask, mrchrishill, I have a few ideas up my sleeve but I haven't fully worked them out yet.
Drew
Old 03-24-2011, 07:40 AM   #995
mcbassin
Still Learning
mcbassin's Avatar
Drew, did you already say in here what kind of paint you're shooting? Is that single stage acrylic enamel, urethane enamel, or polyurethane? It looks great, btw, I know first hand about critters in the paint (still have one or two I need to buff out of my son's paint). I have had another fun problem with sweat building up on me and dripping on the paint. If you wear coveralls hood and resporator it gets HOT. keep the pics rolling!
Old 03-24-2011, 09:32 AM   #996
silverboy02
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Post #855 shows he is using Nason acrylic enamel
silverboy02 is offline   Reply With Quote
Old 03-24-2011, 09:37 AM   #997
JasonBird
'67 C-10 LWB Driver
JasonBird's Avatar
i doubt it, but i'll let ya paint my truck for free!
67Cheby probably take you up on that offer, in fact we'll pay next years member ship fee for you for painting our rigs! JT
'67 C-10 LWB - My Build Thread
'67 C-20 LWB - My Donor/ Parts truck - SOLD!
'92 GMC SAFARI VAN - My Parts Go Getter
'06 KIA SPORTAGE EX - My Commuter
"All of this crap better make a truck!" - my wife Sue.
Proud U.S.M.C. Dad!
JasonBird is offline   Reply With Quote
Old 03-24-2011, 09:40 AM   #998
67cheby
67cheby
67cheby's Avatar
thats for sure
Old 03-24-2011, 10:16 AM   #999
drewskiren
drewskiren's Avatar
Yes, just the least expensive acrylic enamel single stage. I usually shoot base/clear, but it is so large, I didn't want to spend the time or money.
Drew
Old 03-24-2011, 10:27 AM   #1000
drewskiren
drewskiren's Avatar
WOW, 1000 posts and 66,000 views !!! Thanks everyone, couldn't have done it without you.
Drew
