Old 03-22-2011, 04:22 PM   #1
justinburnett
justinburnett's Avatar
Tried to kill myself.
So... I had to get my transmission out, and I've never done this before. 1973 K20, basically stock height maybe plus an inch or two. Anyway I've pulled the engine before so I figured I'd just leave the transmission on and pull both out since I don't have a trans jack or a lift. Had all sorts of problems, finally got it moving and I couldn't get it high enough to clear the core support. Dropped it back down, and ran the arm out to the last setting which SAYS good for 1000lbs. Lifted it up, got it almost high enough and the damned thing spun sideways a little and got overbalanced and started to go ass-over-tea-kettle on me. Now of course, being a retard with no healthy regard for anything large and heavy that's swinging around in the air at face level, my friend gets under the damned thing and tries to catch it instead of just letting it go. I jumped on the side of the hoist and managed to get just enough weight to get it to settle back down. We were up on about 2 1/2 wheels there for a second. That'll get your heart pumping.... anyway, we got it back in line and managed to move it away and drop it back down to where it was manageable. I'm really glad it worked out like it did, but I definitely ripped my guy a new asshole for getting under 600lbs+ of steel. I would have been more than happy to watch it destroy my fender and shatter on the ground than crush a friend, no matter how little of a survival instinct he has. Anyway, just a heads up to anyone who hasn't done it, be very careful. Next time I'll let some air out of the tires so I don't have to lift as far, and maybe just pull them one at a time. Also the jack is getting stabilizers next time I have my welder handy.
justinburnett is offline   Reply With Quote
Old 03-22-2011, 04:28 PM   #2
allengator
allengator's Avatar
Re: Tried to kill myself.
Who got ripped a new one for extending the boom but not extending the legs of the hoist?? (or buying a hoist with out extendable legs??)
J/K.... glad y'all are ok!!!
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 03-22-2011, 04:39 PM   #3
84C30
OMG! I've seen it happen more than once, it's not much fun is it? Thank god both of you guys were not hurt. Let it go it's easier to fix it then try to heal.
84C30 is offline   Reply With Quote
Old 03-22-2011, 04:42 PM   #4
meter swinger
meter swinger's Avatar
Thumbs up Re: Tried to kill myself.
Well, most of us have some stupid stuff. Kudos to you for having the stones to post it.
meter swinger is offline   Reply With Quote
Old 03-22-2011, 04:58 PM   #5
justinburnett
Hey, I don't mind admitting my mistakes (to anyone but my wife), if it could save someone a lot of hurt or frustration later. And yes, it is my fault for buying the cheapo China-hoist in the first place.
Old 03-22-2011, 05:06 PM   #6
Pop's C-10
Pop's C-10's Avatar
That'll get tha red flowing...good & bad...
Pop's C-10 is offline   Reply With Quote
Old 03-22-2011, 05:20 PM   #7
Clyde65
Clyde65's Avatar
I remember a friend inviting me over to "help" him pull his motor in HS, he had a chain wrapped over a tree and a come along moving the engine and trans out, tree branch broke, landed on his car, totaling car, mom was screaming her head off, dad was p1ss3d because the tree scratched the newly painted barn. I never went back for anything automotive related, figured I learned my lesson on the first time. Redneck at its finest.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-22-2011, 05:42 PM   #8
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Glad you're both OK. Learn from this and you're good to go.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 03-22-2011, 07:03 PM   #9
wyattglock
wyattglock's Avatar
Good to hear you made it through that alive! I know the way I had to yank my engine and trans wasn't the most graceful, but just remember that if you think it might be unstable. It most definitely is!
wyattglock is offline   Reply With Quote
Old 03-22-2011, 07:22 PM   #10
Altec
Getcha Pull
Altec's Avatar
Sounds like your friend tried to kill himself.
I always do the engine and trans separate unless I have the core support out. Which in some cases is worth the time if you don't have the proper tools to help remove the transmission. Even the extra time not killing yourself, and give you all the room in the world.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-22-2011, 07:59 PM   #11
72 Super
72 Super's Avatar
Glad you both are okay, it could have been a lot worst. Thanks for posting as we can all learn from situations like this.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 03-22-2011, 09:57 PM   #12
Psycho71
Psycho71's Avatar
Glad nobody was hurt. But let me tell you something about your friend, you might already know. That guy is a good one to have around in a pinch. He might not always make the most intelligent decisions, but give me one friend who will react under pressure, and I'll give you five who won't.
Now I'm not advocating anyone dive under a SBC and trans to keep it from hitting the ground or truck. But the simple fact that he reacted, and didn't just turn and run, tells me a little about the fella.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 03-22-2011, 10:19 PM   #13
justinburnett
Yeah, you got something there. Wouldn't pick anyone else to have around if things went wrong.
Old 03-23-2011, 07:22 AM   #14
BigBlocksRule
That'll make you pinch a hole in your shorts, huh? I've had a few near-misses, it only takes once to really get your attention. I quit pulling engines and trannies together, too much opportunity for disaster.
Don't be too hard on your buddy, there's not a lot of time to think when everything starts tipping over...
BigBlocksRule is offline   Reply With Quote
Old 03-23-2011, 09:51 AM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
With the engine up in the air going over the rad
I always tell my kid to stand back,cause he's always wanting to be helpfull
I tell em we'll pick it up when the dust settles
and everbody plays with steeltoes boots or shoes(now seen steeltoe sandels too lol)
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-23-2011, 09:59 AM   #16
timjt
gota watch those steel toes, we wouldn't let anybody wear them on the construction site (mason work, its ok for framers) because the boss figured it was better to crush a toe than get the toes stuck in the pinched metal.
2001 silverado stolen by family
1983 short n wide custom deluxe SOLD
1985 silverado longbed 305 engine 700r4
OH NO! NOT ANOTHER LEARNING EXPERIENCE!!!
"Just because you can do it, doesn't mean that you should"
timjt is offline   Reply With Quote
Old 03-23-2011, 10:43 AM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
well here on a job site it would be shut down with out steel toes
no matter what the boss says It's the law
I'd still prefer to drop a brick on my boots over runners
and an engine lol
John
Old 03-23-2011, 10:52 AM   #18
baclay9
Your boss should watch mythbusters....
baclay9 is offline   Reply With Quote
Old 03-23-2011, 11:05 AM   #19
timjt
lol, never saw that episode. Just knew I had to go buy a $80 pair of boots when I started working for them.
Old 03-23-2011, 11:11 AM   #20
motornut
78K & 79C Jimmys
motornut's Avatar
Nov 9th 2005 didn't see that one
John
Old 03-23-2011, 11:14 AM   #21
timjt
thanks, I'll youtube it and maybe send him a link
Old 03-23-2011, 03:31 PM   #22
motornut
78K & 79C Jimmys
motornut's Avatar
I tried to find it no luck
John
