Old 03-21-2011, 05:19 PM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Hood Hinges
What is the deal with the hood hinges? When the back of the hood stick up is that from a worn hinge?
Is there a low buck fix with the old hinge?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-21-2011, 07:08 PM   #2
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Hood Hinges
Crazy question, did you try adjusting the hinge? If so what's the position of the hinge at the front and rear bolt?
Alan's Classic is offline   Reply With Quote
Old 03-21-2011, 08:12 PM   #3
61_FL_Apache
Who Me?
Re: Hood Hinges
I dont think the front bolt hole is sloted and the rear is down as low as it will go.
Steve
2001 Blazer 4D 2WD
Old 03-21-2011, 09:09 PM   #4
ratskin
Re: Hood Hinges
A friend of mine had that same problem, and it was caused by an inexpensive seal that held the back end up. I turned him on to a seal that folds over like a horizontal V, and that cured the problem. Can't remember where I got it!
ratskin is offline   Reply With Quote
Old 03-21-2011, 10:20 PM   #5
racingdewman
racingdewman's Avatar
Re: Hood Hinges
i have had the same problem with my 66 i have no seal so that shouldnt be the problem i switched hinges it got better but still sticks up . the hinges i switched out were used so i beleive it is a hinge issue hopefully someone can help us on this
racingdewman is offline   Reply With Quote
Old 03-21-2011, 11:08 PM   #6
Alan's Classic
Re: Hood Hinges
I didn't make it out to the shop tonight to do some looking. I haven't tried this idea, but I would try to elongate the rear hole to allow it to be adjusted down some more. If that works then maybe the hinge has some wear. This is a total guess right now. Maybe someone will have a better answer.
Old 03-21-2011, 11:34 PM   #7
rbar
rbar's Avatar
Re: Hood Hinges
I have the same problem. I don't think its an adjustment issue with mine. Each time I close it I have to go to the cowl and push it down. Its like it doesn't close all of the motion up on the hinge. I haven't made an honest attempt to fix it. I wonder if the spring could be an issue?
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 03-21-2011, 11:56 PM   #8
Alan's Classic
Re: Hood Hinges
To be honest I haven't got to adjusting the hood yet. I had a 69 camaro that drove me crazy. It stuck up in the back also. I was 16 at the time and didn't know how to fix it. I took it to Rick's camaro's and I can't remember for sure what he did, but it was completely opposite of what I did. I believe both bolts are adjustable on the 69. I pushed them both down. That didn't work. I believe he raised the front of the hinge up and it fixed it. My point is has anybody tried to raise the rear up? It sounds crazy and probably is, but it's a quick adjustment. Just throwing ideas out there.
rbar might be right as well.
Old 03-22-2011, 01:43 AM   #9
andyh1956
Re: Hood Hinges
before he got the '66 we have now, my son had a '64. one day the hood popped up while he was driving it & after that the hood would never shut right, always high at the back. it fit perfect before & we never could get it back the way it was. sprung?
andy
andyh1956 is offline   Reply With Quote
Old 03-22-2011, 07:16 AM   #10
61_FL_Apache
Who Me?
Re: Hood Hinges
This maybe something to try.
Also, has anyone bought hinges from LMC? If so, did they work better? I saw they were around $45 each.
Steve
2001 Blazer 4D 2WD
Old 03-22-2011, 11:09 PM   #11
protrash64
Resistance is Futile
protrash64's Avatar
Re: Hood Hinges
I have read on the board that it means the hinges are shot, but I have no idea if this is true or not. After reinstalling my 'burb hood I have it slightly out of wack and it doesnt close like before. Could be the hinges fight each other?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-22-2011, 11:23 PM   #12
Alan's Classic
Re: Hood Hinges
I might also remove the hood stricker to eliminate any bind. That way your sure it is only a hinge problem.
Old 03-23-2011, 12:32 AM   #13
Captainfab
60-66 Nut
Re: Hood Hinges
I have fixed a similar situation by just adjusting the hinges. I don't remember the exact procedure, but it took some trial and error to get it right. Sometimes lubrication all the pivot points will also help.
Old 03-23-2011, 09:20 AM   #14
TagMan
Re: Hood Hinges
I have the identical situation, but the hood sticks up only on the diver's side in the rear. I close the hood, push the rear down, get in and drive. I'll take a look at it eventually, but there's a lot more pressing things that need to be addressed first.
TagMan is offline   Reply With Quote
Old 03-23-2011, 09:37 AM   #15
61_FL_Apache
Who Me?
Re: Hood Hinges
Mine seems to be more on the drivers side too.
Steve
2001 Blazer 4D 2WD
Old 03-23-2011, 07:07 PM   #16
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Hood Hinges
Here are the hood alignment instructions from the 1960 Chevy Truck shop manual. The actual adjustments for the rear height of the hood are indicated in paragraph 4 on the 3rd page. The 1st two pages have pictures that are referenced along with other information that may be helpful.
Old 03-23-2011, 07:30 PM   #17
61_FL_Apache
Who Me?
Re: Hood Hinges
Thanks for that info!
Steve
2001 Blazer 4D 2WD
Old 03-23-2011, 09:33 PM   #18
protrash64
protrash64's Avatar
Re: Hood Hinges
Awesome Mark!!! Who's gotten it done yet??
Old 03-24-2011, 07:25 AM   #19
61_FL_Apache
Who Me?
Re: Hood Hinges
Not me so far, maybe this weekend
Steve
2001 Blazer 4D 2WD
Old 03-24-2011, 07:40 AM   #20
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: Hood Hinges
Great info Mark,thank you
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
