![]() Join Date: Dec 2008
Suggestions on body mount/cab mount kit?
I'm almost at the point of mounting the body and getting this truck to paint before final assembly. Any and all suggestions welcome. Should I go rubber, should I go poly? Why, which manufacturer? My frame is a 68 GMC 4x4 1/2 ton SWB.
Thanks in advance! Neil |
Re: Suggestions on body mount/cab mount kit?
Over 12yrs ago I went Energy Suspension Black Poly Body/tranny/xfercase mounts. My rubber mounts were toast.
The trick with Poly is not too over tighten or squeese it. Then use a nylon lock nut too keep the mount secure. I have had zero issues eversence ![]() Oh and I was told Black has polygraphite impregnated within to prevent "poly squeek" Red does not have this feature. ![]() ![]() ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
