03-24-2011, 08:47 AM | #1 |
Electrical issue with turn signals
Ok I am haveing an issue with the emergancy flashers on my truck staying on all of the time.
This is a 68 chevy stepside Does anyone have a copy of an electrical print for this truck Also any recomendations for a book like a hayne manual or something for this truck seems like there are a few books out there but what are the beter books to buy Thanks |
03-24-2011, 09:35 AM | #2 |
Re: Electrical issue with turn signals
welcome to the board
first place i'd check would b the flasher switch on the column factory service manuals are readily available in quality reprints. check the vendor list on the main page as most good board vendors will have them at very reasonable prices the manuals have factory wiring diagrams
03-24-2011, 11:36 AM | #3 |
'Burban Legend
Yes, probably that whole turn signal switch set up. I used to have a phobia of them, but they are actually fairly easy to install. Just go slow and write anything down you may think will be important on the re install. Especially if you get called away in the middle. Both Chiltons and Haynes have the info in them. Your local parts store should have the switch or be able to get it Hope this helps, Mike
'67 Chevy Iron City Beer Truck (9ft step) '67 Chevy Panel Truck 467 '68 Short Fleet 305v6 '68 McLaren Ramp Truck '68/'68/'70/'71 Burbs 292/366/402/454 '69 C-30 dump '71 C-50 dump and church bus '71 4x4 454 '72 Blazer (w/pop-up camper) $15 x-hooks '66 Chevy II 194/Weber '68 El Camino" 305v6 '69 Skylark 455 Buick '70 Chevelle 427 '71 Cutlass W-31 '71 GTO 400 2x2 "The 51" Chopped '51 Chevy (409) my first car OK Toad, we'll take 'em all... John Milner |
03-24-2011, 12:43 PM | #4 |
The Older Generation
Hi Joe,
Welcome to the board. If you scroll down to the bottom of this page you will see the FORUM JUMP box, click on the little down arrow on the right side and scroll down to "Electrical" in the window that pops up and click on it. When you get into the electrical section you will see a heading close to the top that says "Color Wiring Diagram Finished". Click on that. If you have some free time there are a lot of interesting areas to explore in the FORUM JUMP box. Check 'em out... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-24-2011 at 12:47 PM. |
