Old 03-24-2011, 10:28 AM   #1001
67cheby
67cheby
67cheby's Avatar
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
no problem 66001
67cheby is offline   Reply With Quote
Old 03-24-2011, 10:34 AM   #1002
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Yesterday when I was block sanding the fenders and doors, I found some scratches and a few ripples. So last night I re-primered everybody. I'll final block today and be ready to shoot tonight or tomorrow.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 03-24-2011, 10:38 AM   #1003
butternut1972
butternut1972's Avatar
WOW Drew you making great progress. Paint looks great. I can't wait to see this thing done.
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 03-24-2011, 01:33 PM   #1004
drewskiren
drewskiren's Avatar
If anybody is wondering, normally you couldn't get away with painting each part separately, but since this color has no metallic and is so plain, and a lot of it is white which hides well, I should be fine on matching.
Drew
Old 03-24-2011, 01:42 PM   #1005
extd56
extd56's Avatar
I know whe I painted mine I got all the body work done, took it all apart to paint the interior of the cab and jamb everything and then put it all together and then painted the outside of the body. It is a lot of paint.
extd56 is offline   Reply With Quote
Old 03-24-2011, 06:22 PM   #1006
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by drewskiren View Post
Yes, just the least expensive acrylic enamel single stage. I usually shoot base/clear, but it is so large, I didn't want to spend the time or money.
Hey, I totally understand. I have used Nason single stage for cheap pJs for years. I usually go with the uerethane enamel, it's bullet proof for the most part. It sands and buffs nice too when you get the signature marks. The acrylic works good too, but I usually don't do panels like you are doing. So I have issues of dry spots or overspray with it. You have the right idea. Nice work!
1007 posts, and you are just getting started.
Old 03-24-2011, 06:26 PM   #1007
Pop's C-10
Pop's C-10's Avatar
you realy moving
Pop's C-10 is offline   Reply With Quote
Old 03-24-2011, 07:13 PM   #1008
BlueJeep
BlueJeep's Avatar
Can you fill us in on your exhaust fan, or whatever that big duct and thing under the garage door are? Thanks!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-24-2011, 08:11 PM   #1009
drewskiren
drewskiren's Avatar
I guess it would be ok to divulge this information - I have a patent on it, so don't get any ideas.
I used to build furniture as a hobby and this was my dust filter/air cleaner. It used to hang from the ceiling and clear the air of sawdust. I stuck it under my garage door, filled the rest of the open door part with plywood and stuck a flex duct to the outlet. It draws in filtered air from outside,pumps through the duct to the far side of my "booth" and pressurizes the booth with fresh clean air. The pressure of course forces the air and fumes out over the top of the open garage door. It has 3 speeds, but really clears well on low. I'll stir up less dirt on low, so that's what I do. I have the top of the door draped in plastic so the fumes don't end up painting my door for me on their way out.
Drew
Old 03-24-2011, 08:28 PM   #1010
drewskiren
drewskiren's Avatar
Painting a little at a time is so low stress and helps me feel good about checking things off the list. If I have a setup problem, I only have to fix a few panels. When I get a run, it is limited because I am only painting a little. I don't wig out over 1 run. Painting an entire car and I get 7 runs, then I am frustrated and swear I'll never paint again (ask me how I know). Plus this thing is a Monster, I couldn't paint it all at once if I wanted to - They don't make poly booths that big!
Drew
Old 03-24-2011, 10:12 PM   #1011
67chevy1series
67chevy1series's Avatar
well that is a very INTERESTING way of a duct system, bt hey it works and you cant say beep about somthin that does the job, no matter how werid it looks. all the sheet metal is looking good drew keep it up!
67chevy1series is offline   Reply With Quote
Old 03-24-2011, 10:14 PM   #1012
BlueJeep
BlueJeep's Avatar
Very creative, I like it! So since you push air in rather than pull it out you don't need the expensive explosion-proof fan. Do you ever have any issues getting the "fog" up and over the door since it's natural tendency is to sink?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 03-24-2011, 10:37 PM   #1013
VA72C10
VA72C10
VA72C10's Avatar
You've got a nice setup for the taping/masking there!
Old 03-24-2011, 11:55 PM   #1014
drewskiren
drewskiren's Avatar
No explosion proof needed in this setup! No problem at all about fumes sinking. A little air bleeds out at the duct connection on purpose to stir things up at ground level slightly. Don't want to put too much air down low because you run the risk of blowing up dust off the floor, but that seems to be all it needs.
Drew
Old 03-24-2011, 11:58 PM   #1015
drewskiren
drewskiren's Avatar
The tape/paper tree is a must!!! I put off spending the $100 for years - dumb.
Tonight we set the TV up outside so we could sand and watch the NCAA tournament !!
Drew
Old 03-25-2011, 09:29 AM   #1016
drewskiren
drewskiren's Avatar
Still building up my low spots with primer, I'm close and will do a guide coat before I sand next.
Drew
Old 03-25-2011, 09:38 AM   #1017
67cheby
67cheby
67cheby's Avatar
great progress as usual
Old 03-25-2011, 11:31 AM   #1018
68 TT
Still plays with trucks
68 TT's Avatar
In the body shop I worked in we had the fresh air coming in up high and the exhaust was pushed out down low on the opposite side of the booth. Since the fumes tend to sink it worked very well this way. You could easily duct your outlet air under the door instead of over the top and make your booth more efficient and improve visibility with this switch.
Before we painted anything we wet down the floor of the booth and the CMU block walls then brought the parts or vehicle in and sprayed them. It really helped keep the dust down. This might help your booth work better too.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 03-25-2011, 02:27 PM   #1019
Stubbs67
Stubbs67's Avatar
looks great, nice "booth" too! downdraft is more efficient. i would pump my air duct to the ceiling. then unblock the bottom of the garage door. also a screen is a must if you do any night painting. stupid bugs love the sweet smell of the paint. and the light reflectivity of it too.
67 Short Step Project -My other wife, ya know... (she takes all my time and money and I don't even realize it)
88 Subaru wagon 4wd -Daily driver and workhorse
98 Subaru Forester S - Wife and baby wheels
My Build Thread!
http://67-72chevytrucks.com/vboard/s...d.php?t=433751
Need step tail gate and bed front, driver door, both front fenders (both are bondo'd nightmares). can trade fleetside bed parts real straight (except sides) or pay some cash (i am pretty broke)
Stubbs67 is offline   Reply With Quote
Old 03-25-2011, 03:28 PM   #1020
1969~C-20~Heavy-Half
1969~C-20~Heavy-Half's Avatar
What body shop did you work at? I live in Spokane, have my whole life.
1969~C-20~Heavy-Half is offline   Reply With Quote
Old 03-25-2011, 03:36 PM   #1021
68 TT
68 TT's Avatar
It was a very small shop on the north side called D&L Motors. They have been out of business since the owners wife died a decade ago or so. He bought and repaired wrecked newer trucks primarily and didn't take much work outside of his own. Mostly just family & friends jobs, nothing off the street.
I didn't work there long but learned a lot while i was there.
Old 03-25-2011, 09:26 PM   #1022
drewskiren
drewskiren's Avatar
Here is what I am up against and a good opportunity to explain a guide coat. I have some ripples at the bottom edge of my doors. I suspect most doors came this way since they are both so consistent. I have been sanding long strokes in a cross pattern and longways front to rear with my long block. The divots that are low don't get sanded because my block is pretty stiff and it glides right over the top of them. To help me see them I have sprayed a fine mist of black paint, a guide coat. Now when I sand down the high spots, the low divots that need filling show up very easily as black spots. Time to lay in some thick primer and do it all over again.
Drew
Old 03-25-2011, 09:38 PM   #1023
JasonBird
'67 C-10 LWB Driver
JasonBird's Avatar
looking good Drew!
'67 C-10 LWB - My Build Thread
'67 C-20 LWB - My Donor/ Parts truck - SOLD!
'92 GMC SAFARI VAN - My Parts Go Getter
'06 KIA SPORTAGE EX - My Commuter
"All of this crap better make a truck!" - my wife Sue.
Proud U.S.M.C. Dad!
JasonBird is offline   Reply With Quote
Old 03-26-2011, 09:23 AM   #1024
67cheby
67cheby
67cheby's Avatar
would a glazing putty work better in your low spots and then primer???
Old 03-26-2011, 11:49 AM   #1025
fencepost
fencepost's Avatar
A trick I use on the giude coat is lacquer spray can. It sprays very thin and light so it gets a little in all the lows, pinholes, and such. Is cheaper than 3M dust and designated spray guide coats.
Love the build
fencepost is offline   Reply With Quote
