Old 03-25-2011, 02:58 AM   #101
laid_out_70
laid_out_70's Avatar
Re: building my first lowered truck
Originally Posted by big_b View Post
cool build!
what size rims and tires are you running on your truck? i noticed they are 8 lug 3/4 ton? i wasnt aware you could buy lower profile tires for 16.5" rims but im new to this 8 lug game.
thanks
ill check for you tomorrow if i remember. and im assuming they are just passenger car tires. overall tire height is 26"
My Build Thread. 70 C-20, SFBD, angled Z, 3 linked. impressive for a noob?
http://67-72chevytrucks.com/vboard/s...d.php?t=438132
laid_out_70 is offline   Reply With Quote
Old 03-27-2011, 10:37 PM   #102
laid_out_70
put the bed on the chevy today. makes me want to finish it some day.
Old 05-27-2011, 01:55 AM   #103
SSchevimp
cool build, anymore progress? are you up in yucca?
70 c10 long bed
57 chevy 2 door wagon
07 tahoe
96 civic commuter
SSchevimp is offline   Reply With Quote
Old 07-02-2011, 11:13 PM   #104
laid_out_70
quote from c10forum.com so you know where im at
Originally Posted by shawneeboy57 View Post
heres the latest, buddy of mine thats a great fabricator wants to trade me work for my rims. so were working out a deal for him to build me a raised crossmember. anyone have specs on a custom crossmember or remember where any threads are relating to the matter. im thinking raised 2", 1" shorter per side and 1" forward with rack and pinion steering. let me hear your thoughts people
^^^scratching that idea most likely due to my buddy having about 2 months of work ahead of him before he would be able to get started on a crossmember for me.
current plan: 2" Z to lay the frame flat and using 2"x4" to do a SFBD. going to put the tubing in the bottom of the frame, cut the top of the stock frame off, and move the body mounts down.
question for you guys, i only need roughly 1" of body drop to lay rocker but 2x4 is several inches shorter (height wise) then the stock frame. should i over body drop so i can be another 1" or so into the rocker? give me input and insight on that please.
well heres the progress from today:
got the front clip and wiring loom off. also sealed up all open lines
got the interior cleaned out, seat out and doors off.
also the bed unbolted, air management out and most of the air line and wiring loom clamps removed.
plan for tomorrow is to get the cab and bed off. if im lucky the motor/tranny out also.
Old 07-04-2011, 01:42 AM   #105
laid_out_70
progress from today. first i got the cab and bed raised off of the frame. cab fell once and landed on my distributor. ill see at some point if i damaged it.
then i got the motor and tranny pulled.
got the motor on the stand
i have a few questions about my tranny, its a TH350 btw. first, when i pulled it what im assuming was water came out of the lines, any ideas why? then next, where the kick down cable bolts to the tranny, the hole is stripped. how would i fix it?
Old 07-09-2011, 02:33 AM   #106
laid_out_70
picked up a 20' stick of 2"x4" .188 wall to start the SFBD!
Old 07-11-2011, 02:04 AM   #107
laid_out_70
anyone even following my build on here? lol
well i had the intensions of getting the frame going on the chevy this weekend BUT i drug a hole in my gas tank in the yota. i did pick up a 20' stick of 1/2" X 1/2" tubing for the chevy to use as frame braces to keep it square during surgery.
i patched the gas tank with JB weld, then raised it. also put bolts in the upper control arms, lol.
there's a pic of the chevy, haha
Old 07-11-2011, 09:54 AM   #108
hbchevy
hbchevy's Avatar
Looks good...keep it going!
- Scott
My 70 lwb build http://67-72chevytrucks.com/vboard/s...d.php?t=472866
hbchevy is offline   Reply With Quote
Old 07-11-2011, 11:53 PM   #109
laid_out_70
aww a reply
Old 07-12-2011, 12:17 AM   #110
project 67 sub
project 67 sub's Avatar
keep at it and it will be their before you know it
project 67 sub is offline   Reply With Quote
Old 07-16-2011, 03:10 AM   #111
laid_out_70
well i got really lucky and came across a free parts truck. going to take the bed, bumper, tail lights, tail gate, interior parts, door handles, radiator, and much more. going to get started on it tomorrow.
Old 07-17-2011, 01:28 AM   #112
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Just checkin in on the build...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-17-2011, 01:21 PM   #113
sduckworth13
sduckworth13's Avatar
Nice build, looks good, and lots of work. Awesome job, can't wait to see it finished.
Scott
sduckworth13 is offline   Reply With Quote
Old 07-17-2011, 08:20 PM   #114
bigguy69
dazed and confused
bigguy69's Avatar
looks great
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 08-02-2011, 04:12 PM   #115
laid_out_70
well ive been lazy about updating this. got the truck down to bare frame and started the SFBD
frame all on its own
built a frame for the cab but its to flimsy. lol!
then got the frame on my buddies s10 with just us two. it was a b!%@%h!
its new home. yes! that is a garage. im so stoked to be able to work on it regardless of the weather. also have any tools id ever need at my disposal.
got the first side mocked up
then lots of trimming and test fitting
got both sides tacked in by the end of sunday night.
should be working on it 2-3 days a week from now on. probably going to have my buddy build a crossmember after all and maybe arms too. boxing in most of the frame and im tempted to re bag the rear already. time will tell i guess.
Old 08-02-2011, 07:07 PM   #116
Wbrown
Wbrown's Avatar
Is there a reason you ran 2x4 inside
the frame instead of just using like 1/4'' and boxing it? Build is looking great!!
Master welder
I've got a degree in metalfusionology
Wbrown is offline   Reply With Quote
Old 08-02-2011, 11:37 PM   #117
laid_out_70
more material on the bottom to drag and i was going to make it my air tank originally.
Old 08-02-2011, 11:51 PM   #118
No3Fan4Ever
Running on empty
No3Fan4Ever's Avatar
[QUOTE=laid_out_70;4783663]anyone even following my build on here? lol
[QUOTE]
Lot's of people are following your build, look at the view numbers.......;
Great build, you are machine,,,...keep up the great work
We have two rules here at the Rock.
Rule #1: No writing on the walls.
Rule#2: Obey all rules
70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi;
94 Bronco XLT 302, auto;worn out daily driver
No3Fan4Ever is offline   Reply With Quote
Old 08-03-2011, 03:21 AM   #119
Krooked Kustoms
Krooked Kustoms's Avatar
Mate ya not holdin back! good that ya cracking along not doin this before. Keep it up!!
Krooked Kustoms is offline   Reply With Quote
Old 08-03-2011, 05:25 PM   #120
Wbrown
Wbrown's Avatar
Cool just wondering I used my tube chassis on my rock crawler to hold antifreeze, you could set it on fire and not get it to 220.
Master welder
Old 08-05-2011, 05:35 AM   #121
laid_out_70
got a couple hours of work in on the frame tonight
first i cut the top portion off and pie cut the frame section in front.
brought the top frame section down to make the frame a consistent slope
close up
both sides tacked up
heres the next little trick
second side came out cleaner, always works out that way.
bam!
Old 08-07-2011, 04:23 AM   #122
laid_out_70
did work today!
welded in these filler pieces first
then these for the front
also welded up the pie cut front portion
then the inside
next i sanded down everything.
then i welded up the front section of the 2x4" to the stock frame. the bottom portion has about a 1/2" gap and was a mission to weld up.
then i started welding the 2x4" to the stock frame, the top portion. i did 3-4" stitch welds alternating from left side to the right frame rail. (some of the decent beads)
this is from the first pass
got it all welded up on the top by the end of the day
and this is my new daily, traded my bagged yota for it. now i have the best of both worlds
Old 08-07-2011, 07:52 AM   #123
Cameron 1137
Cameron 1137's Avatar
Nice work on the frame! this truck is a work of art.
Cam
1972 Chevy C/10 "Custom Cruiser Project" Build Thread
1961 Olds Super 88 (Daily)
1966 Chevy Corvair 500, "Marigold" SOLD
2005 Subaru Outback Wagon DEAD
2008 Pontiac G8, New Winter/Daily
Cameron 1137 is offline   Reply With Quote
Old 08-07-2011, 11:04 AM   #124
Krooked Kustoms
Mate!! Ya did a bloody good job on that frame. Im hooked on this thread!! Haha. Makes me want to bag mine.
Old 08-08-2011, 12:59 AM   #125
laid_out_70
thanks guys, it is scary that this is my first build and ive only been fabbing for about a year now? lol
