Old 07-14-2003, 02:30 PM   #1
Ruckus
Newbie- Question
Hi everyone.
I'd been looking for a truck to restore for over a year....finally bought one about a month ago. It's a 70 cst lwb. I wanted one I could drive home and around town while I fixed it up. I've been replacing more critical items so far and while underneath it replacing a leaking trans. pan and gasket, saw what I think is the center support bearing broken. It looks like it was replaced not all that long ago (cleaner looking). My questions are: It wasn't broken when I got it, so should I replace it now- I still haven't filled the trans yet, if that makes it easier; and can I get this at an auto parts store, or from the likes of lmc (about 30 min. away). The truck isn't my d.d., so that's not a problem. Thanks for any advice. Here's a pic
Ruckus is offline   Reply With Quote
Old 07-14-2003, 02:35 PM   #2
Ruckus
Here's the truck if that helps
Old 07-14-2003, 03:13 PM   #3
jhwkns
Registered Cruiser
jhwkns's Avatar
First of all. Welcome to the board!
Usually when a carrier bearing fails such as yours did there are most likely other problems with your driveline. Take your complete driveshaft to a shop and have it checked out. It is well worth the investment. Good luck with your truck. John
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 07-14-2003, 03:33 PM   #4
rambler
MOVE OVER
rambler's Avatar
Welcome to the board as well, I would agree, there could be something else wrong that caused the damage to the bearing, doenst look like normal wear-n-tear
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 07-14-2003, 03:42 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Again, welcome to our home. (I call it home anyways)
I also agree about the damage. Seeing that it is a new piece and it is already dead, something else has to be doing it. Those things can last 30 years. (with some luck...but not unheard of)
Before you take the shaft to a shop, check all 3 U-joints for stiffness,a dn then look ar the rear axle to see if it is crooked or had just been installed. (new hardwear or obviously re-used stuff) If the pinion angle is wrong, it can do this, even though it would be more likely to blow a U-joint first.
Save future agervation and replace all 3 joints while it is out.
As for LMC, many of us on here have had very bad luck with them. You do have the advantage of looking at the part and compairing it with the original so you have way more control over it than us, but be aware of there many inferior parts.
Old 07-14-2003, 04:04 PM   #6
Ruckus
Thanks for the heads-up on other problems. What's better to do- take the driveshaft out to take it to a shop, or drive the truck over and have it checked out? I think the rear axle isn't quite centered- could that be a possible cause?
Thanks again
Old 07-14-2003, 05:48 PM   #7
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Mine looked like that, After I bounced the driveshaft off of a rock at the lake!
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 07-14-2003, 07:24 PM   #8
Class of 69
Class of 69's Avatar
Taking it out allows a driveshaft shop to check it for straightness, replace u-joints, and carrier bearing, and BALANCE it. It appears by the pic that this has happened before. It could just be a cheap bearing, and failed prematurely, but like the others have said, it really should be checked over carefully before reinstallation. You could replace the u-joints youself before taking it to the shop, and save some money on labor. If you do change them yourself, be sure to get good quality,Heavy Duty u-joints, as the cheap ones will fail. They should also be greaseable. Hope this helps, and WELCOME to the board.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 07-14-2003, 10:32 PM   #9
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 07-14-2003, 11:05 PM   #10
Longhorn Man
Class of 69, personally, I prefer the non-greasable ones.
The hole for the zerk fitting creates a weak spot (which doesn't really matter onless you have butt loads of torque...but worth mentioning), and I figure if the stock O.E. sealed units lasted 140K on my wife's old S-10 blazer (4.6 vortec)...then I am sold on them. They actually out lasted the rest of the truck.
Plus, I am lazy and hate messing with the grease gun, and in reality, this is one place that is commonly skipped at jiffy lube, and they won't even blow smoke up your tail pipe, they'll flat out tell you.
NOTE...Jiffy lube is just an example...by Jiffy lube, I mean pretty much all oil chainge places
