Old 07-13-2003, 11:24 PM   #1
1971gmcshortbed
1971gmcshortbed's Avatar
auto trans driveshaft
i removed a 4 speed compound tranny from my 71 GMC, i'm installing a 700R4, anyone know if i'll need to build a driveshaft or can i find one by application?
1971gmcshortbed is offline   Reply With Quote
Old 07-13-2003, 11:47 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
You will proably have to have your current driveshaft shortned several inches. I would go ahead and bolt the 700R4 in and see how your stock driveshaft compares in lenght. The 700R4 proably uses a different yolk than your four speed. Any driveshaft shop should be able to take care of that for you. Maybe a good time to go with a one piece driveshaft.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-14-2003, 12:00 AM   #3
1971gmcshortbed
yea, the 4 speed yoke is bolted to the tranny, and it's 2 piece, i definitely want to 86 that sucker. i think hydramatic 350's use same yoke size as 700.
Old 07-14-2003, 12:36 AM   #4
Phillip Johnson
Phillip Johnson's Avatar
I vote for the one piece shaft!
Phillip Johnson is offline   Reply With Quote
Old 07-14-2003, 04:12 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You are correct.
I guess I'll be the first to welcome you to the board.
Where you located? What's your truck's specs?
Old 07-14-2003, 05:27 PM   #6
Linus0014
Guest
Posts: n/a
Welcome from So. Cal
Old 07-14-2003, 08:39 PM   #7
Low69CST
I just had one made for my short bed. I think it was 58" and 5/8th.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-14-2003, 08:42 PM   #8
GasHog396
A TH350 shaft should fit. The 396 engine in my '67 short bed ate the TH700R4 that was in there before I bought the truck, so I swapped in a rebuilt TH350 I had it laying around. I used the same driveshaft with no modifications at all. Only had to move the trans cross member, drill some new holes, replace the TV cable with a detent cable and rebend the coolant lines, and away she went. I would love to have an OD in there, but I will have to have one made a little more robust to live behind the 396. That, and the cost was right for the TH350.
'67 1/2 Ton Short Bed / 396 cid / AC w-R134a / 5 Lug Leaf spring rear axel / 5 Lug Frt Disk Brake Conversion
'97 Trans Am - Black / LT-1 / K&N FIPK Cold Air Kit / Hooker Cat-Back Exhaust / 160 Thermostat
'02 Buick Regal GS / Bone Stock
GasHog396 is offline   Reply With Quote
Old 07-14-2003, 11:14 PM   #9
Longhorn Man
Gas hog, it sounds like you had a 200 4R and not the 700R4. The 200 is the same overall length as a short TH350, the the 700 is no where near the same length.
Old 07-14-2003, 11:43 PM   #10
GasHog396
Thought is was 700R4, but could be wrong. Didn't look too hard at it, as the fluid was grey with metal and there were 'chunks' in the pan. It was toast. Guess it didn't like that big block torque too much. Oh well, the TH350 works just fine. Now if I can just get the mileage into the double digits I'll be happy.
