Old 03-27-2011, 12:03 AM   #1
62ShortStep
62ShortStep's Avatar
Re: hydraulic clutch
If you want more throw, you need to make the master a larger bore, or make the slave a smaller bore.
62ShortStep is offline   Reply With Quote
Old 03-27-2011, 12:48 AM   #2
Captainfab
60-66 Nut
It sounds like you need a larger bore master for the size of the slave cylinder you are using. You want the bore of the master to be equal to or slightly larger than the bore of the slave cylinder. IMO having them both the same size bore works best. The largest bore available for the Wilwood 260-1034 is .750". If you need a 1" bore, you will have to go with the Wilwood 260-6766.
In the power brake conversion kits I sell for the '60-'62's, I include either a 260-6766 or a 260-6764, depending on the slave cylinder being used.
Old 01-10-2015, 03:16 PM   #3
rokflint
How do we figure know which slave cylinder bore size we have?
rokflint is offline   Reply With Quote
Old 01-11-2015, 01:16 AM   #4
Captainfab
60-66 Nut
I replied to your PM regarding the purchase and this question.
The best would be to remove the slave cylinder and actually measure the bore size. If it is an original style '60-'62 slave cylinder, it should have a bore of 1-1/16"
