Need Help Quick
Does anyone know of a year truck that used a 12.75 inch flywheel? I'm looking for a starter that will work with the 153 tooth flywheel.
Thanks |
Do you have a manual transmission on your truck?
Starters for the 153 tooth flywheel should be plentiful, (bolt pattern is straight across instead of diagonal) as a lot of cars came with them. They will bolt to the block and work if you have an automatic. If you have a stick then I think you will have to change the flywheel. Good luck! Jim |
| Bookmarks |
