Closed Thread
Old 03-26-2011, 06:05 PM   #1976
bsteele
Re: What did you do to your truck today!
Just got the headers on. Had to go in from the bottom. Only issue looks like the bottom of the pass. side frame rail may touch a little. I didn't tighten 'em down yet. They are full length super comp. hookers for a '73 to '87. They came with the motor when I traded for it.
bsteele is offline
Old 03-26-2011, 07:49 PM   #1977
mightymouse
mightymouse's Avatar
[img][attach]Name:  Project 72 021.jpg
Size:  43.6 KB[/attach][/img]my hooker supercomps hit the frame rails on each side on my 72
mightymouse is offline
Old 03-26-2011, 08:11 PM   #1978
wwotr
wwotr's Avatar
Originally Posted by mightymouse View Post
[img][attach]Attachment 720337[/attach][/img]my hooker supercomps hit the frame rails on each side on my 72
Had the same problem on my 67.
My Mechanic had to cut a small notch out of the Frame.
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline
Old 03-27-2011, 12:40 AM   #1979
ItsRandy
ItsRandy's Avatar
Got the holes in the crossmember cut and lined with sch40 and then painted. Tried to install my brand new $750 Hooker headers...they don't fit. You would think for all that money they would jump out of the box and onto the truck all on their own!
ItsRandy is offline
Old 03-27-2011, 08:44 PM   #1980
bucketObolts
bucketObolts's Avatar
today I spent an hour in the back of my parts store trying to find a rad. hose that would clear my engine driven compressor belt. I had a flexhose with the spring inside and I dont even wanna now how much rust an/or pieces of rotted spring got sucked into my engine. I bought 2 that didnt work and just as I was going back to the store I almost fell over a full built 318 I have sitting in the garage. Wouldnt you know it there was an almost perfect hose right in front of me the whole time. After trimming 3 inches it was perfect! I started pulling my interior apart and took my console out to upgrade air valves and put in my painless kit. Then got sidetracked and wound up remaking the whole front half of my console for a smoother curve. I didnt go too crazy with it since Ill be pulling it out again when I get a radio and speakers someday. The console would be a perfect spot for a sub and some 6x9's.
bucketObolts is offline
Old 03-27-2011, 11:49 PM   #1981
keanevann
Channeled my bed 4 inches so i can run my air ride and still have full use of my bed.... Cut a longbed floor down to a shortbed floor because the PO had destroyed my shortbed floor (He used to drag race the truck so he cut half the floor out for a fuel cell and tubbed it)... Then I cut down the tubbed inner fenders to stock + 2 inches....
P.S. Thanks to ka_jd7and1 for the bed floor... much appreciated
keanevann is offline
Old 03-28-2011, 12:17 AM   #1982
ItsRandy
ItsRandy's Avatar
Yesterday I posted that my new $750 Hooker headers wouldn't fit. After more investigation and trimming of the driver's side lower control arm (drum roll) they fit (almost). Turns out Hooker, in their wisdom, didn't relieve the header flange to clear the head bolt heads that are installed on a ZZ502 crate motor, so, the headers are on my truck but I need to replace 8 head bolts with head bolts that have shorter bolt heads. Anyone heard of this before?
ItsRandy is offline
Old 03-28-2011, 12:46 AM   #1983
jjtackleberry
jjtackleberry's Avatar
Watched it get snowed on....
anyone know where to get a CHEAP yet GOOD truck cover
'71 Chevy LWB all OG
'86 Chevy LWB all OG
It's all a matter of perception
jjtackleberry is offline
Old 03-28-2011, 01:16 AM   #1984
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Been making a punch list to wrap up my 4x4 conversion/Cummins install.
Also took the old fiberglass visor pos off.
Still a lot to do, but right now its looking like a truck again.
Until I blow it all back apart to finish boxing the frame. Then it will go back togeather after each piece is painted with POR-15
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline
Old 03-28-2011, 02:56 AM   #1985
project 67 sub
project 67 sub's Avatar
drove it to church, had a few people looking at it and asking a few questions, than looked at it myself and said....... i have the lowest vehicle in the parking lot
project 67 sub is offline
Old 03-28-2011, 09:39 AM   #1986
6772owner
Gearhead
6772owner's Avatar
Project: That is awesome.
Over the weekend, I installed an ECE hidden hitch on my 72', installed the trailer wiring, remounted my compressor (interfered w/the hitch) and recalibrated my govenor in the 700R4 (what a pita!)
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline
Old 03-28-2011, 09:43 PM   #1987
70C10Toejam
Hellasick
70C10Toejam's Avatar
Took longer that "Today", thanks to the wonderful roller-coaster weather we've been having and a minor bout with the flu, but I got my new exhaust manifolds installed.
Engine was replaced in '97 and around 40,000 miles since then. Bolts came out nice and easy. The doughnut gasket between the manifold and pipe on the pass. side was pretty much blown out. Now I can hear my exhaust tone and not the exhaust leak
Before---there is also an "R" on the passenger side that you cant see. Guess the guys that put in the engine couldn't tell the difference. The pass. one also has a big crack that you can't see in the pic.
Thought I would give the Rust-oleum 2000* paint a try on the new ones.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline
Old 03-28-2011, 10:24 PM   #1988
Slick67
Sofa King Crazy!!
Slick67's Avatar
I cursed at mine today. Then went to the engine builder and cursed him.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline
Old 03-28-2011, 11:59 PM   #1989
justagoodolboy
Under Construction
justagoodolboy's Avatar
I hauled mine to the paint guy this evening! But like a comple idiot I never thought to take pics till I was on the road, so now I have none since my truck is back together .The guy said he would buy an sd card and take some before he starts on it so I'm hoping he doesn't forget. It should be done in a month so I gotta get some stuff ordered and figure out if I wanna reuse the seat that was in it so when I get it back I'll (hopefully) be ready to get right on it.
72 chevy 4x4-my project
67-72chevytrucks.com/vboard/showthread.php?t=368210
94 Nissan 4x4-Daily Driver and off road beater
03 Saab 9-3 -tripper
90 Polaris Trail Boss- 2 Stroker
justagoodolboy is offline
Old 03-29-2011, 12:04 AM   #1990
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Drove it to pick up stuff for home construction project only to discover my thermosat housing leaks still. I have a crappy chrome one that I stripped the surfaces and also used forma gasket on the reinstall. I let it sit for 2 days before filling the radiator. On the plus side, no speeding tickets today!
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 03-29-2011, 01:32 AM   #1991
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Did some more prep work so I can weld my frame back together (the other day I started the lwb to swb conversion). Almost ready to get welding!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline
Old 03-29-2011, 01:45 AM   #1992
ItsRandy
ItsRandy's Avatar
Built the bracket for my oil cooler and painted it, pictures tomorrow.
ItsRandy is offline
Old 03-29-2011, 04:37 PM   #1993
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Found out that I have a bad lower ball joint on my left front wheel, and you brake line is most likely collapsed too. Those pads were smokin' when I was able to pull over to check 'em.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline
Old 03-29-2011, 06:16 PM   #1994
glider_6969
Actually Sunday, put some gas in it and fired it up for the first time since I added the power brakes, and power steering and new mechanical gauges.
It all worked,,,, I even took it for a quick spin around the block.
68 Long stepper
My other ride ,,, 07 Streetglide..
glider_6969 is offline
Old 03-29-2011, 11:49 PM   #1995
eagleuh1
eagleuh1's Avatar
Used it to roll a perfectly good travel trailer in the median of Hwy 65 in Pine Bluff Arkansas. Came uncoupled for some reason at 70 while passing a Coleman Dairy truck. Jerked on the safety chains couple times while I tapped my brakes to get off cruise and hit my trailer brake controller to try and straighten it back up. It finally just shoved my rear in the air and drove me into the median and jacknifed then wipped around and rolled. The truck with my Honda 1800 stayed upright and bike stayed put. Glad I used 4 straps.
Luckily no injuries, just my pride. Rear bumper and bracket damaged, as well as rear bed cross brace, but repairable or replacable.
eagleuh1 is offline
Old 03-30-2011, 12:10 AM   #1996
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
****!!! Sorry, Man.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 03-30-2011, 12:18 AM   #1997
stich626
Well, last week I dug out some stereo gear from my 97 f 150 that I installed in 98 and pulled when it was totalled in 2000
and desided to install the old junk that isn't worth anything in the truck
The doors where already cut front and rear for 6.5" speakers so I opened the rear hole and installed my boston acustic 6 by9s and pioneer 6.5"
I also had some kickpanels and a set of cerwin vaga(remember them) 6.5" two way seperates
the woofer is in the kick the tweeter in the dash
next was the really old jbl and kenwood amps
and then cut the crap out of my arms try'n to get this in the dash
and re installed the seat after a little rework
now to fit this blazer tank under the bed
this brace under the bed must be cut
all gone
there is another brace behind this one so it's not a big deal, if I was to use it like a 3/4 ton truck then,,
I'm gonna cut the brace at my cut about 3/8" and fold it in and weld it so it'll have a little added strenth..
after that sand and sand and then some por 15
stich626 is offline
Old 03-30-2011, 12:38 AM   #1998
wwotr
wwotr's Avatar
[QUOTE=eagleuh1;4587722] The truck with my Honda 1800 stayed upright and bike stayed put. Glad I used 4 straps.
[QUOTE]
That looks like a Honda VTX 1800C....No?
Glad you & your Truck are alright.
Hello members...
RIP...."RATIKLE"
wwotr is offline
Old 03-30-2011, 12:46 AM   #1999
pulltilbroke
pulltilbroke's Avatar
Pulled the old 15" slots off and put the old 16.5 slots on.
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12
67 C-20,292,SM420,HO72
90 Dodge W250 Cummins,NV4500HD,205,D60/D80
93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70
pulltilbroke is offline
Old 03-30-2011, 12:47 AM   #2000
60ratrod
yes, i do
60ratrod's Avatar
Where did you get the dash pillar stich?
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline
Closed Thread
