Old 03-26-2011, 12:48 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
DIY4X B-52's?
Anybody use the DIY4X B-52's? I'm thinking about replacing the hangers on the rear of my burb to be able to adjust the height of the suspension depending on what I am hauling. Thanks, Bradley
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 03-26-2011, 01:16 AM   #2
Altec
Getcha Pull
Altec's Avatar
Re: DIY4X B-52's?
B52 brackets are used on the front?
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-26-2011, 02:02 AM   #3
scottsdaleowner75
Re: DIY4X B-52's?
B52's are for the front. The rears should already be 52' if a 1/2 ton rig. 64' is preferred to making it articulate and smooth riding for the rear.
scottsdaleowner75 is offline   Reply With Quote
Old 03-26-2011, 02:01 PM   #4
thirdstreettito
Resident of Here
Re: DIY4X B-52's?
Why couldn't I use them in the rear? Also, I dont want 62's! God, what is that, a 12" lift?
~Bradley~
Miss having a truck
Old 03-26-2011, 04:38 PM   #5
Altec
Getcha Pull
Altec's Avatar
Re: DIY4X B-52's?
Because the perches wouldn't line up for starters, and it is just a waste of money.
Spring length doesn't set how much lift they have. Arch, and spring rate do. A 62-64 install gives roughly a 4" lift.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 03-26-2011, 04:57 PM   #6
thirdstreettito
Resident of Here
Re: DIY4X B-52's?
Damn, I want adjustability, but I can't afford air right now. 4" is too much lift, I want a 2" MAX.
~Bradley~
Miss having a truck
Old 03-26-2011, 05:32 PM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: DIY4X B-52's?
Do a shackle flip in the rear. Offroad Designs makes a 2.5" lift and 4" lift versions. I put 2.5" lift ones on my '84 CUCV M1010 ambulance. http://www.offroaddesign.com/catalog/shacklekit.htm
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-26-2011, 06:47 PM   #8
thirdstreettito
Resident of Here
Re: DIY4X B-52's?
Once again, I want a MAX lift of 2".
~Bradley~
Miss having a truck
Old 03-26-2011, 07:23 PM   #9
Zoomad75
K5Camper
Zoomad75's Avatar
Re: DIY4X B-52's?
You don't need to get testy dude. He just gave an option. What you asked for really isn't made. Nobody makes a kit, hangers or other to allow the springs to bolt up one way for a certain height and another way to add 2", 4" or whatever you want.
What you are really looking for to have ability to adjust on the fly would be installing rear air bags to aid in the load. When used you can adjust the level of the truck with adding air if load is added to it. When the load is off, letting air out brings it back down. If you really want to get to another level, install an onboard compressor and controls to adjust the ride on the fly.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 03-27-2011, 12:08 AM   #10
'63GENIII
'63GENIII's Avatar
Re: DIY4X B-52's?
Damn Mike, that truck is cool!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 03-27-2011, 12:30 AM   #11
thirdstreettito
Resident of Here
Re: DIY4X B-52's?
I already addressed air...
I wasn't getting testy, just reminding him I said 2" lift.
~Bradley~
Miss having a truck
Old 03-27-2011, 12:31 AM   #12
scottsdaleowner75
Re: DIY4X B-52's?
First off educate yourself. 52' springs are the LENGTH not the height of the lift. Those are the standard rear spring length in half ton apps. A longer spring articulates more and gives a better ride. YOU CANNOT USE A B52 KIT IN THE REAR. The adjustability doesn't work the way you believe it does. In fact since you dont understand it avoid it. The serious off-roaders use that kit. Since you are not one of them just buy a 2' lift! http://www.ntwonline.com/76-87_GM_1_..._P8377C823.cfm
Of just buy some junkyard 1 ton springs. Those will net you about 2' or just get a 2' block if you want to go real cheap.
Old 03-27-2011, 09:55 AM   #13
Re: DIY4X B-52's?
Your Suburban has 56" springs in the rear already. That shackle flip is 2.5" vs 2" and that matters? A 1/2"...Really? Maybe you need to vary the line you draw as much as ride height varies from vehicle to vehicle. Ok,then scratch that. You're not looking for lift anyway,right? You want load gross/net versatility. You didn't specify your budget,but a pair of Rancho 9000RSX shocks will cost under $200 and give a range of ride like no other shock. I used these on my '91 diesel 'Burb with Ez-Ride springs. It rode really nice on the softest setting and allowed full flex. I always had the 6' cargo area (ran two seats) full of building tools. The few times I had them out it seemed to ride the same. I only changed the setting when I towed. The tongue weight made for a washy ride. With the shocks set all the way to firm it rode just right. On that setting with no trailer it rode like a rock over bumps.
Old 03-27-2011, 10:12 AM   #14
AJs72K5
AJs72K5's Avatar
Re: DIY4X B-52's?
If you're worried about the height of the rear end when towing, add a set of overload springs to your rear spring packs, or get a set of bags, or air shocks.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 03-27-2011, 01:21 PM   #15
Redcap
Re: DIY4X B-52's?
Redcap is offline   Reply With Quote
Old 03-27-2011, 07:53 PM   #16
chevy_mike
chevy_mike's Avatar
Re: DIY4X B-52's?
Personally if you can tell the difference between 2" and 2.5" you're better than me. I suggested the 2.5" version as this is about the only way I have seen to get that in the rear easily and at minimal cost. If it HAS to be MAX 2" then my friend, you could be SOL... Build your own parts at that point or fork over $$$ for custom springs.
Just trying to help out. YMMV
