Old 03-27-2011, 09:35 PM   #1
dsy1
body bushing bolt welded to the floor
I would like to replace my body bushings but I don't want to lift off the cab. Below is the driver's side bolt from inside the cab, it has a huge weld bead compared to the small tack weld on the passenger side. How hard will this be to cut and remove?
Any other tips? Thanks...
dsy1 is offline   Reply With Quote
Old 03-27-2011, 09:38 PM   #2
cdowns
cdowns's Avatar
Re: body bushing bolt welded to the floor
shouldn't b bad it really depends on you mechanical skill level
Old 03-27-2011, 09:45 PM   #3
72lb4x4
Mine are like that too...
I've got a few almost used up cutoff wheels lying around waiting for that job.
72lb4x4 is offline   Reply With Quote
Old 03-27-2011, 09:53 PM   #4
dsy1
The bolts are recessed so it would have to be a small cutoff wheel to keep from damaging the floor.
Old 03-27-2011, 10:27 PM   #5
JohnT71
Just cut it, if you damage the bed floor a little you can always put a washer under the bolt head to cover.
JohnT71 is offline   Reply With Quote
Old 03-27-2011, 11:54 PM   #6
Sequoyah
so easy a caveman can do it...
Sequoyah's Avatar
cold chisel ftw!
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=242380
Sequoyah is offline   Reply With Quote
