Hellasick
![]() Join Date: Jul 2006
The manual says my truck should be a stepside, not fleetside. Was checking out the manual why doing the curing process for manifold coating and
VIN starts CE140J, manual says 4 is stepside and 34 is fleetside. Nothing unique on the SPID. Did it get changed, or is this common?
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys Last edited by 70C10Toejam; 03-28-2011 at 10:12 PM. |
Re: VIN differs from truck bed
C= 2WD
E= V8 1=1/2 ton 4= pickup 0= 1970 J= janesville assy. plant It's your model number that will tell you step or fleet. Last 2 digits.
CHEVY/GMC VIN DECODERS |
Hellasick
So why does the manual say 4-Stepside Pickup, 34-Fleetside Pickup on the page that explains the VIN???? GM just that confused???
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
model type 04 is cab and stepside bed
model type 34 is cab and fleetside bed I don't know why it's under the vin page, but it's the model number that tells what kind of bed not the vin.
Is this a GMC???
Hellasick
Looked at the model on the SPID, and the last 2 are "34", Just gotta love it when the manufacturer provides information in multiple places that contradicts itself.
Hellasick
Everything says its a Chevy, but now I wouldn't guarantee anything
The vin is in chevy format so your good there. Is your model number on the SPID (should be)??
#9 | |
Hellasick
Just saw post 6. 34 is fleetside so your good to go.
Hellasick
In my work, I just run into this kinda stuff all the time. In a manual for a charger control it says it is set for "X" as factory default and just below the list of those options is says "Y" is the factory default
![]() ![]() ![]() How can one option have 2 different factory default settings?????
#13 | |
Hellasick
At least it didn't say it was a COE
#15 | |
The Older Generation
It's just your karma Chad, just your karma... ![]() LockDoc
