#101 |
Re: Tre5 Customs roadster blazer project
Making good progress!
#102 |
VA72C10
![]() Join Date: Mar 2008
Awesome! Love the flush caps where the stake pocket went
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#103 |
I assume those are not floating calipers if you've run hard line all the way on them?
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#104 |
No, they are floating. I have never had a problem running the hard line straight to a floating caliper. I use stainless steel annealed line, it is more flexible when annealed. The only down fall I see doing it this way is that whenever the owner goes to replace rear pads he will have to disconnect the hard lines and re bleed the brakes... Once every 40,000 miles or so, so really not that big of a deal.
Follow me on facebook and Instagram. Tre 5 Customs My '49 http://67-72chevytrucks.com/vboard/s...d.php?t=673809 Customer build: 67 Blazer Roadster http://67-72chevytrucks.com/vboard/s...d.php?t=443105 Customer build 1980 C10 http://67-72chevytrucks.com/vboard/s...49#post7210949 |
#105 |
![]() ![]() ![]() Got the Grant Customs skin welded up and installed the 15" AVS led tail lights installed. My buddy Will came over and helped out a bit. I had to get a picture of someone other than me working on the truck, so here he is... drilled who knows how many holes in the floor piece.
#106 |
Almost done with the tranny hump. Just one small patch panel on the drivers side to finish up.
#107 |
Your metal work look great. I like your rear lights in your tail gate. subscribed
________________________________ 1972 SWB stepside pro tour build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452840 |
#108 |
looks good man!
#109 |
67cheby
![]() Join Date: Sep 2008
clean....as usual
#110 |
Cam 1972 Chevy C/10 "Custom Cruiser Project" Build Thread 1961 Olds Super 88 (Daily) 1966 Chevy Corvair 500, "Marigold" SOLD 2005 Subaru Outback Wagon DEAD 2008 Pontiac G8, New Winter/Daily |
#111 |
ok, finally back to work on the blazer. I got the 1" narrower Porterbuilt arms on and the hood now closes.
The standard arms from them were a bit too wide for the 24's to fit under the hood. With them now 1" narrower the tires clear the roll in the hood. I also got the Porterbuilt hood hinges on and all the front end mounted up. Now I just need to add some support in the fenders as well as a place to hide wires up underneath the fender support. Then weld up the front Grant Customs roll pan and fill all the little holes in the hood, grill, and fenders. ![]() Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help.
#112 |
![]() Join Date: Apr 2004
great build.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#113 |
chevy only
![]() Join Date: Sep 2006
nice work kat!!
CHEVY ONLY... Nothin Else ! |
#114 |
First time it has been out of the garage!
![]() ![]() ![]() ![]() Does the windshield need to be laid back?
#115 |
oldschoolblazer@yahoo.com
I like what I see, next time you're in So.Cali bring it out
![]() We would Love to see it up close and in person |
#116 |
VA72C10
looking good!!!
#117 |
Its coming along nice!
#118 |
chevy only
very cool , again nice work!!
#119 |
67cheby
could you set something across the top of the fenders and tell me how much your tires stick up above the top of the fenders, if you dont have time that is fine but if you do it would be a good little bit of research for me
#120 |
![]() Join Date: Jul 2010
layin it back would look killer,,,
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
#121 |
No, it will disrupt the lines.
#122 |
67-72 parts collector,…
![]() Join Date: Nov 2002
#123 |
#124 |
IMO:lay it back to match the angle on the hood...
#125 |
