Old 03-29-2011, 03:08 PM   #14
clinebarger
Re: 6.0l LQ4 to old school tranny
Originally Posted by 67shortie View Post
My engine came off of a 4L80 so the flexplate had the correct adapter already there so all I had to do is elongate the converter holes to mount the 700 to it.
You should not have to mess with the converter bolt holes on a "4L80E" flexplate
Originally Posted by jkade View Post
GM PART # 12621399 $44.42
That has the flexplate, spacer, and bolts. All you will have to do is do a little grinding with a die grinder on the new flexplate to match you converter. The bolt holes are close but you have to open them up a little. Working fine on my LQ9/th400 and you won't beat the price!!!
Is that what you got from GM parts direct? If so, Its wrong, Looks like a 4L60E flexplate. It should look like this, Notice the 6 converter bolt holes.
clinebarger is offline   Reply With Quote
