Fabricate till you "puke"
the upper a arms, & the crossmember will work. You need to swap the lower a arms(due to ball joint sizing), then swap all the ball joints to go 1/2 ton(5 lug)+ tierod assys(inners, outers, & sleeves). The center link may or may not work......just watch the taper on the holes when you install the tierods. as a rule, 71 on is a go on the center link. Also, you can use 73 up spindles......just use the corresponding ball joints, & outer tierod ends.( the upper ball joint, & outer tierod ends have a different taper on the 73 up 1/2 tons) Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 07-15-2003 at 10:32 PM. |
| Bookmarks |
