Old 03-30-2011, 06:23 PM   #1
tim21391
tim21391's Avatar
Bed Bolt ?
bout to drop $50 at lmc.. went to lowes and priced each and every bit... gonna be the same cost... needing the whole bed bolt kit to put a bed together its like 300 some piece.. where does a guy go to look at some of the kits.. is lmc the only place?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-30-2011, 06:42 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Bed Bolt ?
If you are going to spend $ on bolts, I would recommend getting bolts made for
your application. BTW-bolts not only vary by grade (read strength) but by quality.
Follow the vendor link in my signature...we have several Board Vendors
who specialize in bed related hardware.
If you find someone close to you, you can actually see what you are buying.
You can also go to the Vendor Forum HERE, where you will often find great sales!
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
