Old 03-30-2011, 07:18 PM   #1
jimmyboi082
Question powerglide fitment?
New to the forum and just bought my first 1966 chevy shortbed. The truck has a 250 cid with a powerglide. I was wondering if I can install a 1989 chevy 350 block to the powerglide? Will the flywheel bolt up right? will the trany bolt up right?
jimmyboi082 is offline   Reply With Quote
Old 03-30-2011, 07:59 PM   #2
PGSigns
PGSigns's Avatar
Re: powerglide fitment?
It all will bolt right up.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-30-2011, 10:27 PM   #3
70cst
70cst's Avatar
Hey jimmyboi082 ... and from Ohio. Glad to have you on board
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-31-2011, 12:53 AM   #4
Captainfab
60-66 Nut
You will have to use a '86 and newer flexplate on that '89 350. I'm pretty sure that will have the correct bolt pattern for the PG torque converter.
Old 04-03-2011, 03:56 AM   #5
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: powerglide fitment?
Now here is one you might want to try the power glide and the th350 are the same size and bolt up the same one has a kick down rod and the other has a cable.The best thing about it is the th350 is a 3 speed one more gear.Now they made 2 th350 one is a lock up converter and one dose not you should really look into it there are a lot of th350 out there and if you want a major kick in the pants try the 700R4 now you have gas mileage and a over drive Now you need to cut down the drive shaft and move the cross member back
Here are the transmissions i;m talking about the power glide the th350 the th400 and the 700R4
Now remember they made 2 power glides One for the truck witch has the small nose cone and the car power glide that has the long nose cone not sure if i had both of them in my pictures so take a look remember the 1987--93 are the only 700R4 you want the ones before it they need to many valve body and case updates
I need to take better pictures for you to understand what they look like and i will do better for ya i need a week to get them all out and lined up and cleaned up so you can see the differences
stsalvage is offline   Reply With Quote
Old 04-03-2011, 03:58 AM   #6
stsalvage
Scrapper 1
stsalvage's Avatar
one more time last picture was of a th350 short shafted now the blue one is the 700R4
