Old 03-31-2011, 07:40 AM   #1076
ERASER5
ERASER5's Avatar
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Was that Muppet skin interior?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-31-2011, 09:06 AM   #1077
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Originally Posted by jbclassix View Post
Something like this might be easy to install
That is STUNNING!!! I'm going for it - in blue of course.
Now I just need a you tube how to video.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 03-31-2011, 10:33 AM   #1078
Beat68CST
Beat68CST's Avatar
Something more like this blue?
http://www.hollywood-diecast.com/up%20in%20smoke.htm
2nd pic down (:
Beat68CST is offline   Reply With Quote
Old 03-31-2011, 11:27 AM   #1079
drewskiren
drewskiren's Avatar
2nd pic down (:
Maybe on the back window I could have a graphic made that says " The Frankenlove Machine "
Drew
Old 03-31-2011, 11:47 AM   #1080
bundeber
It looks like someone skinned Chewbacca and made a seat cover...
New to this thread, Excellent work, both on the truck and with your home building. Attention to detail always takes good work to the next level.
As to the headliner, you can buy backing material, it's sort of a cross between cardboard and masonite, and you could fit that to the roof. The only real problem with this is that you're going to end up with a flat roof, putting in a complicated curve for the corners is going to be almost impossible. It's basically like trying to build a geodesic house without any sharp corners.
Here's an idea that might work.... lay out a good thick sheet of plastic over your roof, the top of it, then cover that with fleece. Basically the interior of the cab should look like the outside of it, just slightly smaller....
Then coat the fleece with resin. When it sets up give it a test fit, you'll probably have to do some trimming around the A B and C pillars to get it to fit, but I would bet this would get you pretty close. My guess is that when you drop this down it will fit pretty tightly, there will probably be about 2 inches of extra material around the edges that would need to be trimmed off. With that fitting snug, you could flip it over, put a few boards around the edges to keep it propped up and cover it with 2-3 layers of fiberglass and resin, then use some filler to make it smooth. It could then be covered with something stretchy to finish it, or block it smooth and paint it.
Just a thought and no idea if it would really work, but 20 dollars in fleece and 60 in resin doesn't sound like a bad gamble....
Other options include....
If you still have the spare cab from the other truck, or the front of the already cut cab, but I think I saw you took them to the boneyard, you could cut out the interior second layer of metal from those cabs and weld it in. This would give you the finished metal curves you needed there, then a sheet of 16 gauge could be welded in between those pieces to finish it to give it the stock look of a pickup.
The only other real option I see is doing one much like the cars of that era with the bows and headliner material with loops that fit around the bows.
It's a big mess to try to tackle, any way you slice it, you have some work to do, and an upholstery shop is probably going to charge you more than you spent on paint, primer and filler.
bundeber is offline   Reply With Quote
Old 03-31-2011, 01:44 PM   #1081
drewskiren
drewskiren's Avatar
Thanks for taking the time to give me ideas. Part of my issue is trying to save money, so avoiding the upholstery shop is a priority.
I like the fleece over my top idea a lot. I had seen lots of videos online of people making custom door panels, but it was always a convex curve - stretched tight across something. A headliner is a concave shape, but your idea of using the outside of the roof solves that!!! I have built laminated mahogany canoes before with multiple coats of resin and fiberglass, so I know what a mess it will be, but I think I will try it.
Drew
Old 03-31-2011, 01:57 PM   #1082
hgs_notes
GEARHEAD
hgs_notes's Avatar
3M spray adhesive works for holding fabric on those concave areas rather than just pulling it tight. This is used for door panels, and headliners all the time.
hgs_notes is offline   Reply With Quote
Old 03-31-2011, 03:16 PM   #1083
bundeber
Talking Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
HGS_NOTES
Yeah it does hold well, but we're just talking about building on some plastic sheeting that's draped over the truck roof, gluing it down would require some stretching and then it would pull the plastic back up, unless you secured the plastic somehow. Basically it will probably form some wrinkles, but that should be pretty minimum in order to get the initial curves needed to make the custom headliner...
Drewskiren
My pleasure helpin out. I've been mulling over one of these projects for some time now. And when I stumbled on your thread It was perfect timing. I'm just finishing up a 68 camaro restoration, looking to sell it and move back to my 68 pickup. The wife and I would like to have another kid, and that means a truck has to be large enough for the whole family, which really makes this build idea a winner. I just hope the Camaro Resto hasn't scared her too much!
Old 03-31-2011, 03:26 PM   #1084
Hart_Rod
Hart_Rod's Avatar
Give these guys a call, I be they could help you out with the headliner...
http://www.roddoors.com/pages/chevtrk-6787.html
Hart_Rod is offline   Reply With Quote
Old 03-31-2011, 03:46 PM   #1085
gcburdic
Restoration Virgin!
gcburdic's Avatar
Rob....I think they are out of business
here's the Home Page with the sad news....http://www.roddoors.com/index.html
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-31-2011, 05:20 PM   #1086
Hart_Rod
Hart_Rod's Avatar
Dang, I missed that. Too bad, they had some really nice products.
Old 03-31-2011, 05:26 PM   #1087
VA72C10
VA72C10
VA72C10's Avatar
Roddoors is back in business but I think it's someone who bought the rights....I actually read about that on here...
can't find the link right now but I did look it up before and they had many of the same products available...
Old 03-31-2011, 07:53 PM   #1088
drewskiren
drewskiren's Avatar
Taking the plunge on the headliner. I went and bought some fleece, resin, Fiberglass mat and Woven Roving (heavy cloth). I'll need to dive in before I paint my roof in case I have any screw ups - probably next week sometime. Tonight I am going to try and mount the HVAC under the dash for the last time.
Drew
Old 03-31-2011, 08:09 PM   #1089
Pop's C-10
Pop's C-10's Avatar
You may have to make a frame out something like 3/16 rod so that you can bend it to tha shape of the roof & do tha fabric and fiberglass cloth outside tha truck.
Pop's C-10 is offline   Reply With Quote
Old 03-31-2011, 08:24 PM   #1090
drewskiren
drewskiren's Avatar
I am laying 4 or more layers of .7 mil plastic on the roof, laying the fleece on that, pouring resin out over the fleece and using a roller to spread it out. Once it hardens, see how it fits inside. I am planning on covering the A,B, and C pillars with upholstery like the headliner to make the cab super quiet. I think I will cover them first and then attach the headliner for a neat seam around the perimeter.
Drew
Old 03-31-2011, 11:22 PM   #1091
mjensen
mjensen's Avatar
As if I didn't have enough reasons to check this thread out! Now I'm gonna have to see how the headliner turns out Seriously though, the project is looking great.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 04-01-2011, 12:16 AM   #1092
jbclassix
Junk Yartist
jbclassix's Avatar
This actually a good idea! So the original burb Headliner had a sort of "c" channel it sat in, right? Well, (since you are already painted welding is out of the question) I think that hardware stores have a screw-in-type C-channel that is used to hold vinyl panels in place on walls and ceilings... what about getting some in chrome and you should be able to screw it in place where you want it all the way around the perimeter.
You then take said 3/16 rod and bend "roof bows the way you want, and a perimeter ring. Weld them to create a headliner frame. Now you take your fabric and lay it OVER the bows and UNDER the frame. pinch the fabric together and sew it on the inside (the side you would see). Then fold it around the frame and sew that. I think this will give you a stitched seam that will look good. Then your headliner should literally snap in place...
I may just be crazy, it HAS been a long day.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 04-01-2011, 12:44 AM   #1093
drewskiren
drewskiren's Avatar
Firewall has a few more items now.
Drew
Old 04-01-2011, 12:57 AM   #1094
drewskiren
drewskiren's Avatar
And here is the reason.
A/C completely bolted in with wiring attached. A side note; I forgot that I had cut the bottom edge of the dash about 2 feet wide under the radio area. I sectioned this area about 1 inch to clear the depth of the new unit. I still need to make a plenum and route my 4 air ducts (new ducts on order). I don't know that I would recommend this mod. for everyone because I am losing my radio slot and I have to use a modern controller. I am planning on putting the controls a little out of normal view, so as to not ruin the old school effect with late model Chevrolet parts. That being said, it should cool the truck very effectively. I put a 3 inch wide piece of tape to simulate my lower dash valence panel. I will also have to relocate my old keyswitch into this new panel that runs the width of the dash.
Drew
Old 04-01-2011, 07:39 AM   #1095
VA72C10
VA72C10
VA72C10's Avatar
Nice progress!!!
Old 04-01-2011, 09:09 AM   #1096
drewskiren
drewskiren's Avatar
Garage caught fire last night, I must have left the space heater on. Truck is ruined - I can't even think about it.
I'll be back though, maybe I can salvage something.
Drew
Old 04-01-2011, 09:15 AM   #1097
67cheby
67cheby
67cheby's Avatar
ha ha....happy April 1st to you my friend
67cheby is offline   Reply With Quote
Old 04-01-2011, 09:16 AM   #1098
gopokes
gopokes's Avatar
Harsh April fools joke I'm praying!
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224
gopokes is offline   Reply With Quote
Old 04-01-2011, 09:29 AM   #1099
mcbassin
Still Learning
mcbassin's Avatar
You had me going for a second there......bam
Old 04-01-2011, 09:59 AM   #1100
thor
thor's Avatar
Nice try Drew!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
