Old 04-01-2011, 02:28 AM   #1
michael b
help with rear end choice
what type of rear end would be best to put in my 1985 chevy long wheel base . it has original rear end but want posi rear . has a 350 4bolt main with 350 tranny . any suggestions
michael b is offline   Reply With Quote
Old 04-01-2011, 02:32 AM   #2
iluvmy72
Re: help with rear end choice
Just make sure her ass looks as good as a.....oh wait you meant rear dif....oops!!
iluvmy72 is offline   Reply With Quote
Old 04-01-2011, 02:58 AM   #3
my4by2
my4by2's Avatar
You've prob got a stock 10-bolt. It's a good enough axle for what you have. Just put in the ratio you want & add some kind of Posi set-up if it's in your budget. Other than that just change the fluid & replace the axle shaft seals & you'll be good!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 04-01-2011, 09:29 PM   #4
michael b
tyvm
Old 04-01-2011, 10:23 PM   #5
sierra4x4
sierra4x4's Avatar
If it was me I'd use the original 10 bolt but add a posi out of a 8.5 10 bolt car such as a Caprice or 70's Camaro. They are a lot better than the gov-lock that was offered from the factory in a 85 1/2 ton.
sierra4x4 is offline   Reply With Quote
Old 04-01-2011, 10:46 PM   #6
willstruck
Rockwell...
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic.
willstruck is offline   Reply With Quote
