04-03-2011, 10:33 AM | #1 |
1971 A/C R134a Retrofit - Low Pressure Schrader Valve stuck
Good morning,
I was trying to remove the low pressure side R-12 Schrader valve to retrofit a R134a valve to make an assesment on my dormant A/C system. The Schrader valve unscrewed to the top of the 1/4 flare nipple, but now turns within the nipple. Should I use needle nose pliers to extract from here? Is it stuck to the seal? Thanks, Frank
Thanks, Frank |
04-03-2011, 03:37 PM | #2 |
Re: 1971 A/C R134a Retrofit - Low Pressure Schrader Valve stuck
If you unscrewed all the way pull it out with a needle nose pliers. If there is any part of the core stuck you can remove with a pick or a small easy out.
Fuzzy |
