#26 |
60-66 Nut
Re: '60-'62 POwer Brake Booster Adapter Bracket With A Clutch
No, no feedback. No one with a 4x4 has bought one. I don't know if that big return spring is a secondary spring that can be eliminated, or not. If it is the only return spring, maybe that one can be removed and replaced with one similar to a 2wd cab. In reading 56taskforce's post above, he thinks that the standoff will bolt on, on top of the spring bracket. If that will indeed work, the standoff will need to be shortened an amount equal to the thickness of the spring bracket.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-07-2011 at 12:10 AM. |
| Bookmarks |
