04-07-2011, 12:00 PM | #1 |
Coil spring vs. leaf spring...
Are the frames the same? I am wanting to change my 68 3/4 with leafs over to 1/2 ton swb with coils spring rear. I have all the suspension left over from another project and the only frame I have found is a leaf spring rear suspension. I thought somewhere that I read the coil spring crossmember can be removed and put into the other frame. Any help? thanks . Jim
04-07-2011, 12:08 PM | #2 |
Re: Coil spring vs. leaf spring...
ive heard the same an may do it as well. although some old school truck dudes keep telling me leafs are better
04-07-2011, 01:03 PM | #3 |
Junior Member
I have had trucks with both leaves and coils. The coil spring truck's ride was a little smoother. The leaf spring truck I had was a 3/4 ton that I used to tow pretty heavy loads.
I guess it comes down to personal preference. Leaf sprung trucks have been around for years, my '92 K-3500 has leaves, they seem to be more stable with heavier loads, less sway. Also it is easier to lower a truck that has coil springs, if that is what you like.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
