high beam indicator light
I was wondering what would cause the high beam indicator light in the speedo to stay on if lights are on low or high beam. I replaced the dimmer switch and its still on. Just wondering if anybody else has had this happen. Thanks
Re: high beam indicator light
same here. I suspect some kind of spacer that wasnt put back when the po changed bulbs. I say this cuz everything else works.
Will check it out one day after the big projects
Ed F 1972 Sierra Grande White Top Medium Olive 402 bb / Camper Stock, Loaded, Straight & Aged Nicely, No Tilt Original Resto would be nice $ ![]() Last edited by Ed 72 Sierra Grande; 04-06-2011 at 11:04 PM. |
its all about the +6 inches
does it dim when you dim the dash lights?
does it get brighter when the highbeams are turned on? do any of your guages act stupid when the lights go on (fuel guage mostly) |
the gauges are acting fine and i havent had the cluster out in along time. I have no clue will try to figure it out this weekend
