04-02-2011, 11:45 PM | #1 |
67 K20 Rockwell 221 shifting question
T-case was rebuilt professionally by PO. Shifts smooth and easy, except....won't stay in 2wd....in the photo below, in the circled area, should there be a nylon or rubber bushing or something? Everything looks and works well on it except it won't stay in 2wd.
Thanks, ya'll.
1962 Chevy K10 factory 4x4 stepside longbed http://67-72chevytrucks.com/vboard/s...d.php?t=494632 1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded 1968 Chevy 1/2 ton panel wagon, V8 and powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=483345 1978 Ford F250, beater stepside 2008 Jeep Wrangler 4 Door 2010 Chevy 4x4 plain jane work truck |
04-03-2011, 11:13 PM | #2 |
Re: 67 K20 Rockwell 221 shifting question
Anyone? Ideas?
04-04-2011, 12:00 AM | #3 |
Custom Builder
I can check my '66 for you tomorrow.
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 |
04-04-2011, 08:59 AM | #4 |
Thanks LeftCoast. I've just about got it back on the road.
04-04-2011, 09:06 PM | #5 |
Custom Builder
I checked mine and all my linkage is soild pins and no bushings. The hole looks worn out completely and you are probably not getting it all the way into 2WD. Go on the transfercase and push the arm on the drivers side all the way back. That should get you all the way into 2WD.
04-04-2011, 09:46 PM | #6 |
What?
I don't have that extender looking thing on mine.
Mine is a 67/68 Rockwell 221.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
04-05-2011, 05:51 PM | #7 |
Thanks ya'll. Not able to move the lever by hand. It moves easily from in the cab, just won't stay put in 2wd. I wonder if my problem is that extra piece in there? I can't seem to find a diagram on the 221 that would show what was supposed to be there.
04-05-2011, 07:49 PM | #8 |
What?
Really hard to tell with the pictures.
But, I am thinking you are missing the shifter support bracket? I don't know, but your set up looks custom.
04-06-2011, 08:11 AM | #9 |
Does anyone kow if the T221 uses detent balls to hold the shift shafts in place? If so, the springs that are used to keep pressure on the balls may have broken, allowing the shaft to pop out of position. I've never really looked at mine.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
04-06-2011, 10:14 PM | #10 |
I picked up a spare 221 from a buddy today, just for a spare, I know parts can be hard to find for these. It looks just like yours, vectorit. I'm going to play with mine a little to see if I can get it to work right, if not, try swapping the shifter mech. over to mine.Thanks all, I think I'm on the way.
04-07-2011, 06:03 PM | #11 |
After playing with the spare today, I see what's happening on mine. I can take a little prybar and get it into 2wd easily. And it stays in 2wd, bounced around the pasture a while to test it. Once I shift back to 4hi, it won't go into 2wd. Looks like I'll be swapping out the shifter mech.
