Old 07-17-2003, 12:07 PM   #1
pappadow
Spring Question
Looking under my 72 C-10 truck, I have the main coil spring, then there is a smaller shorter coil, then there is also a half a leaf spring. Is this an option or 2? Does this mean that I can carry more than a half ton in the truck?
pappadow is offline   Reply With Quote
Old 07-17-2003, 12:13 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
half a leaf spring
Sounds like auxillary overload springs. Those were and option on coil trucks. I believe extra 500 pound capacity, not sure. They bolt to frame and there are pads under the trailing arms for them to rest on.
Not sure what you mean by main coil and shorter coil, unless you have coil over shocks?
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 07-17-2003, 12:18 PM   #3
pappadow
The shorter coil is seperate from the main coil (and shocks), there is a gap so it will only contact the frame if the truck is squatted a few inches. It looks like another overload spring to me.
Anyone else have these?
Old 07-17-2003, 12:22 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Sounds like backyard engineering to me, never seen that. assume the extra coil is on the trailing arm forward of the larger one which should be directly over axle?
Was I correct on the short leaf spring? You should have aux overload or some such verbage on your glovebox for that one.
Old 07-17-2003, 12:25 PM   #5
pappadow
There are two options codes in my glovebox for springs. I think those little shortys are stock. They are directly above the axle. inboard from the others.
Old 07-17-2003, 12:39 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
What are the option codes and descriptions listed? I've seen a lot of trucks but never this . But you learn new things every day!
Old 07-17-2003, 12:53 PM   #7
pappadow
Ive got a
1G5010 Heavy Rear Spring
and also
1G6010 Aux. Spring
Where do you find what these option codes mean?
Old 07-17-2003, 01:02 PM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
1G6010 Aux. Spring
The Heavy (duty) rear spring refers to a stiffer coil (the large one sandwiched beteen trailing arm and frame. Standard duty was standard, the HD was optional. It is not the mystery 2nd coil spring.
As mentioned earlier the Aux spring is the overload leaf.
It appears to me your truck's original owner intended to use it for heavy loads. The additional coil is probably an attempt to futher extend it's capabilities but is not a factory option (IMO). Probably bought a 1/2 ton where they should have gone with the 3/4 ton. It's possible it was used to haul an in-bed camper as well.
The resto pack will give you a lot more detail as what each RPO means.
Old 07-17-2003, 01:06 PM   #9
pappadow
I can't wait for my resto pack to get here I think I still have the original "Highlander" seat upholstry in it, and it's in perfect shape. I wonder if I can find a picture of the original higlander seats anywhere.
Old 07-17-2003, 01:20 PM   #10
COBALT
COBALT's Avatar
The resto pack is interesting, but be ready to be dissapointed. It's not jammed full of all the stuff you ever dreamed you'd get your hands on. It's actually better just to get the chasis, maintenenance, and shop manuals for your year through one of the aftermarket outfits. The resto pack is just extra material...
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 07-17-2003, 01:33 PM   #11
CPNE
Resident Curmudgeon
CPNE's Avatar
Yes but it does give pretty good desriptions of RPO's and other technical info that will help you determine if your truck is "correct" or not, which was the original question. I agree, the chassis overhaul and service manuals give you more "nuts and bolts".
As for the Highlander, that should be listed on your glovebox as "Special Promo" or something like that. It consists of several tiers of options. But all highlanders would have tilt, black carpet, automatics, and a plaid seatcover (orange, blue, avacodo, etc). Only available with Custome Deluxe package which got you chrome trim goodies, etc.
All the details on these packages should be in your resto pack.
Have fun.
Old 07-17-2003, 01:38 PM   #12
CPNE
Resident Curmudgeon
CPNE's Avatar
click here for additional literature for sale
68 Suburban has a lot of this stuff. He had a highlander brochre as well at one point.
Old 07-17-2003, 02:11 PM   #13
pappadow
Thanks for the link!! Looking at the pictures on that for sale post he had the Highlander brochure open to the interior page and guess what..... I do have the original interior seat cover!!! In perfect shape!!
I gotta post some pics of my baby.
Old 07-17-2003, 02:15 PM   #14
CPNE
Resident Curmudgeon
CPNE's Avatar
That's why I posted the link for you. Yes, you OWE us pics!
