Old 04-08-2011, 11:32 PM   #1
Mattman2010
Mattman2010's Avatar
Removing heater box
I am trying to remove the heater box out from under my dash, but I am not really sure how to get it out. I have the A/C/Fan box removed from the fire wall, and all of the ducts/defrosters removed as well.
Thanks, Matt
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 04-09-2011, 10:39 PM   #2
Blue Chevy 1987
Blue Chevy 1987's Avatar
Re: Removing heater box
if your trying to replace heater core its easiest to just cut an access hole to get at it
Blue Chevy 1987 is offline   Reply With Quote
Old 04-09-2011, 11:45 PM   #3
Mattman2010
No I want to remove it so that I can paint my truck.
Build Thread
Build Thread
Thread
Old 04-09-2011, 11:57 PM   #4
tucsonjwt
If you look at a Haynes or Chilton manual you can see how it comes out. As I recall, with an A/C truck you have 4 bolts (I think) and they enter from either side of the firewall. I think the inside bolts are flat head type bolts (like a rivet head) so they are hard to see and up on top of the heater box - use an inspection mirror and a flashlight or just feel around up there until you find them. These bolts are not uniformly spaced, as I recall, and the corresponding nuts on the engine side of the firewall are not easy to find either. I used a ujoint attachment and a flexible socket drive to get to the lower bolts/nuts in the engine compartment, also used the inspection mirror and flashlight trick.
tucsonjwt is offline   Reply With Quote
