Old 03-27-2011, 08:28 PM   #2376
daverod
SSN 706
daverod's Avatar
Re: Daverods project 66
Looking around my garage what did I see. A nice sandblasted and painted 66 manual steering box. Most important it was very tight. 15 minutes later it was on my 64. I forgot I had it I thought I chucked it. Steering is 100% better. Still have a off balance issue coming from the rear. Went to swap my tires I can't get my rear tires off without taking my bed off.?? I think I'm going to rotate my driveline 180 degrees and see if that helps. Then I'll swap my tires.
daverod is offline   Reply With Quote
Old 03-27-2011, 08:56 PM   #2377
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Getting my rear tires off with a 72 rearend is a challenge. It's 3/4" wider on both sides and a 4" drop it's nearly impossible.
Alan's Classic is offline   Reply With Quote
Old 03-27-2011, 11:09 PM   #2378
daverod
SSN 706
daverod's Avatar
Messed with my drive line. Figured out I can't rotate it 180. It's a two piece, it only works one way. I did notice the the u joint was'nt seated very good it had a big notch out of it. Moved my carrier bearing around alittle. You can really move it much. Went for a test drive.What ever I did it's much better now steady as a rock till about 80. Good enough for me. All my driving is in town. I was hoping there was a trick to getting the tires off? Oh well I'm use to take the bed off.
Old 03-27-2011, 11:46 PM   #2379
protrash64
Resistance is Futile
protrash64's Avatar
Dave, are your tires stuck in the rear fenders?? I have to use at least 2 jacks and jack up the frame and the rear axle at the same time. Once the wheel is loose you have to let the rear down until the tire just squeezes out. Sometimes at about a 45* angle. It's a pain. I have 295's on my 'burb. Sometimes you have to let down or jack up the opposite side to get the right angle on the rear axle.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-28-2011, 12:11 AM   #2380
daverod
SSN 706
daverod's Avatar
I jacked the axle up, put stands under the frame and let the axle hang. Then I unbolted the wheels and tried to take them off. No go. I did'nt try jacking the other side of the axle up. Maybe tomorrow.
Old 03-28-2011, 12:11 AM   #2381
shrunken66stroker
shrunken66stroker's Avatar
Same here. I'm going to take off a 1/2" of the fender lip to make it easier. That or roll it under. There's about 1 1/2" of lip so 1/2" shouldn't make a difference as long as the braces are still welded.
shrunken66stroker is offline   Reply With Quote
Old 03-28-2011, 12:13 AM   #2382
daverod
SSN 706
daverod's Avatar
There you go. A little cutting. makes me want to go out there right now.
Old 03-28-2011, 01:31 AM   #2383
watahyahknow
watahyahknow's Avatar
i wonder how hard it would be to make the bed a dumpstyle bed , hinges on the back a locking device (treaded rod a big ring and a wingnut through the bedfloor maibe ?) and airbag to lift it ...... done
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-28-2011, 11:51 PM   #2384
daverod
SSN 706
daverod's Avatar
I'm thinking these are going to catch on.I like the Porche. Maybe they will make a 4-5-6 kit.
Old 03-29-2011, 02:37 PM   #2385
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
They already make 4-5-6 kits. They look really retarted!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 03-29-2011, 03:20 PM   #2386
daverod
SSN 706
daverod's Avatar
Old 03-29-2011, 09:29 PM   #2387
protrash64
protrash64's Avatar
Ever get your wheels off??
Old 03-29-2011, 11:10 PM   #2388
daverod
SSN 706
daverod's Avatar
not yet worked on my 52. maybe this weekend. I'm hoping if I trim the metal I'll be able to get them off. Now I know why some people have fancy dump beds.
Old 04-10-2011, 12:37 AM   #2389
daverod
SSN 706
daverod's Avatar
Did a lot of head scratching. Somthing so easy for some. I don't things don't line up right? Maybe the wrong pulley on the crank? Does the belt for the steering pump go around the crank?
Old 04-10-2011, 12:51 AM   #2390
bubba327
HOW long until spring??
bubba327's Avatar
Looks like your PS pump could be farther back to line up better with the back pulley on the crank . How does the alternator line up??
mine has the belt on the crank back slot , water pump and the PS pump. The alternator drives from the front slot on the crank and the front slot on the water pump.
Use a straight edge or a wood board to line things up. I will clamp a board to a pulley if I am fabbing up brackets and want to stay in alignment.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 04-10-2011, 12:59 AM   #2391
daverod
SSN 706
daverod's Avatar
Its back as far as it goes.Alt. lines up with front grove. The power steering pump has a rear bracket that mounts to the motor mount. It's were it needs to be.??? More head scratching.
Old 04-10-2011, 01:04 AM   #2392
Captainfab
60-66 Nut
The problem is that you have a power steering pump and brackets for the shor water pump. Your engine has the long water pump, and the alternator is of course in position for the long water pump. You'll need to get a PS pump for a long water pump application....'73 and up truck, or '69 and up car. With the long water pump, the PS pump hangs from the water pump from that boss below the lower bolt. Then there are brackets that bolt to the front of the head, and over to the front header bolt. There are some variations to that, but that is the basics. Probably best if you could get everything from a donor vehicle.
Old 04-10-2011, 01:11 AM   #2393
daverod
SSN 706
daverod's Avatar
I also have this pump but I couldn't figure out how to hang it. I had two different engines and things kinda got mixed up. I'll try again in the morning. Hope you have some of those brackets made Capt time gettin closer.
Old 04-10-2011, 01:13 AM   #2394
bubba327
bubba327's Avatar
Bungee cord???
Old 04-10-2011, 01:15 AM   #2395
daverod
SSN 706
daverod's Avatar
Least now I kinda know the problem. I work better with pictures.
Old 04-10-2011, 05:10 PM   #2396
padresag
I didn't read all the replies before I answered .you already had the answer
ron
padresag is offline   Reply With Quote
Old 04-10-2011, 06:59 PM   #2397
allaboutchevelles
allaboutchevelles's Avatar
Hey Dave, I had the same problem when lining up my pulleys. I went to an old junk yard and took all the pulleys off a 283 truck that looked origional and got home and they didnt line up on my motor. I bought some shims off ebay to set the crank pulleys out about 1/8 inch and then eveything lined up perfect. I can get you some pics if you want.
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 04-10-2011, 07:22 PM   #2398
hotroddr
Ran outside and snapped a picture for you. Here is how your long water pump power steering pump should mount.
1968 Firebird
1966 Suburban
hotroddr is offline   Reply With Quote
Old 04-10-2011, 10:10 PM   #2399
daverod
SSN 706
daverod's Avatar
You are the man. Just when I was all depressed. I pulled everything apart and had things everywhere. Guess I'll have to keep better track of parts. Here I thought a 350 was a 350. da Looks like I need to find that little mounting bracket. Thanks Bud.
Old 04-12-2011, 09:42 PM   #2400
daverod
SSN 706
daverod's Avatar
10 boxes an a hour later. wola thanks guys puts me that much closer.
