Old 04-05-2011, 10:54 AM   #326
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Any other projects in your garage?
1969 AMC Rambler American Nostalgia Pro/Street
The curb finders were just for laughs. They are off now.
I did have them on my truck once!
1969 AMC RAMBLER AMERICAN
• Nostalgia Pro/Streeted.
• Hand built from the Ground Up
• Engine Chevy 350ci Destroked to a 327ci
• Made a 4 bolt main 327
• 1971 3970010 4 Bolt Main 350ci 4.020 Bore
• 1968 large journal 327 crank. 5.7 Rods
• Keith Black Pistons to make a bad 327 4 bolt main.
• 1969 441 heads massaged for a crane cam. 292 .501 lift
bump stick.
• Holley 750 cfm 4-bbl Carburetor
• Holley Street Dominator Intake Manifold
• Pertronix Flame-Thrower HEI Distributor
• Accel Heavy Duty yellow Spark Plug Wires
• HP & Torque unknown at this time
• Transmission TH350 with Shift Kit – Built for Street Cruising
• Dual transmission coolers
• 3,000 stall converter
• TCI Cast Aluminum Deep Transmission Pan
• B&M QuickSilver Automatic Ratchet Shifter
• Mustang II IFS (Manual Rack Steering)
• Heidts Superirde Front Coil-Over Shocks for Mustang II Suspension
• Front Stub was Hand Fabricated
• Narrowed Ford 9” Rear End
• 4.56 Gear Ratio
• Detroit Locker
• Leaf Springs on Gas Shocks
• 28 Spline Strange Axels
• Hand Fabricated Suspension
• Rear 1 ½” x 4” Square Tubing 304 Stainless Steel Tubs & Panels
• Wheelbase extended 21/2”
• Exhaust Customized and Hand Fabricated with Exhaust Cut outs
• Home Made Mufflers
• Front Tires: Kumho Tires - Power Star 758 165/80R15 87T
• Rear Tires: Mickey Thompson Sportsman Pro Tire, 29x15.50-12LT
• Front Wheels: Weld Racing Draglite 90-Series Wheel 15 x 4
• Rear Wheels: Weld Racing Draglite 90-Series Wheel 15 x 12
• Custom Interior with a 6 Point Roll Cage
• 15-Gallon Aluminum Fuel Cell
• 1997 Dodge Viper Blue - Professional Paint Job with Old School
Phat Candy Flames
Beep beep beep beep
His horn went beep beep beep
While riding in my Cadillac
What to my surprise
A little Nash Rambler was following me
About one third my size
The guy musta wanted to pass me up
As he kept on tooting his horn
I'll show him that a Cadillac is not a car to scorn
Beep beep beep beep
I pushed my foot down to the floor
To give the guy the shake
But the little Nash Rambler stayed right behind
He still had on his brake
He musta thought his car had more guts
As he kept on tooting his horn (beep beep)
Beep beep beep beep
My car went into passing gear
And we took off with gust (whoosh)
Soon we were going ninety
Musta left him in the dust
When I peeked in the mirror of my car
I couldn't believe my eyes
The little Nash Rambler was right behind
You'd think that guy could fly
Beep beep beep beep
Now we were doing a hundred and ten
This certainly was a race
For a Rambler to pass a Caddy
Would be a big disgrace
Beep beep beep beep
Now we're going a hundred twenty
As fast as I can go
The Rambler pulled along side of me
As if we were going slow
The fella rolled down his window
And yelled for me to hear
"Hey buddy how do I get this car outa second gear?"
Video is when we had the STROKER in her.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 04-05-2011, 11:57 AM   #327
Str8axle
Str8axle's Avatar
The brown primer 55 is in and out of my garage quite often! They gray 55 is on the back burner for now, and the 60 wagon is about to get a re-power. The duece pickup just gets the wheels driven off it!!!
Ray
All my life, I've been told I'm a "Bad Influence"
Str8axle is offline   Reply With Quote
Old 04-05-2011, 12:06 PM   #328
bundeber
Just finishing this one off... Gonna get it done and sell it to finance my 68 pickup. This is fun, but just not functional enough. Gotta have something I can drive year round. This picture was after I got done wet sanding and buffing the car. There's nothing like cleaning all the slime off a car after that... This is atomic orange, a 2008 vette color I believe.
bundeber is offline   Reply With Quote
Old 04-05-2011, 12:47 PM   #329
HillfromTn
HillfromTn's Avatar
Street legal 1980 Camaro, 468 , glide, 9" ford w/5:38, 5.29 1/8th... Name:  007.jpg
[ATTACH]725748[/ATTACH
HillfromTn is offline   Reply With Quote
Old 04-09-2011, 04:49 PM   #330
66ZZ4
66ZZ4's Avatar
I bought this 56 from a girl at work a couple of years ago. It was her fathers car. It was restored 20 years ago. All original with a 265. Part of me say's leave it stock and part of me say's put a big block in it and hot rod it.
66ZZ4 is offline   Reply With Quote
Old 04-09-2011, 06:45 PM   #331
chevyrestoguy
chevyrestoguy's Avatar
Here's my other project:
'55 Chevy stepside, Camaro clip, full air ride suspension, custom cantilever rear, 16x12 ET Fueler wheels. Next step: buy the front wheels, start on plumbing, keep doing fab work. For more info and pics, see the link below.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 04-10-2011, 01:22 AM   #332
RockTonka
RockTonka's Avatar
I've had my 73 CJ5 for over 15 years and have taken it through numerous rebuilds. We try and get it out a few times during the year, but lately it seems like we struggle to find the time.
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 04-10-2011, 12:12 PM   #333
BigJoe29
BigJoe29's Avatar
currently doin a completely new tub for it, rebuilding the 351W and a few other things will be my DD till the 64 c10 is done
Aerodynamics are for people who can’t build engines. – Enzo Ferrari
- 64 Chevy C10 SWB- 440 BBC, Pro touring build in progress SLOWLY
- 73 Camaro LT RS- Pro touring build eventually
- 71 Bronco- my dirt monkey and current focus
The military doesn't pay nearly what it should
BigJoe29 is offline   Reply With Quote
Old 04-10-2011, 02:51 PM   #334
disturbinglykool
disturbinglykool's Avatar
Angelo: No specific plans yet but it will be cool. 70k original mile, one owner 68 C20 with protecto plate and perfect patina.
disturbinglykool is offline   Reply With Quote
Old 04-11-2011, 12:19 AM   #335
old cruiser
old cruiser's Avatar
I have a 38 master sedan slow build
old cruiser is offline   Reply With Quote
Old 04-11-2011, 01:20 AM   #336
Dinos63
chevy only
Dinos63's Avatar
Originally Posted by chevyrestoguy View Post
here's my other project:
'55 chevy stepside, camaro clip, full air ride suspension, custom cantilever rear, 16x12 et fueler wheels. Next step: Buy the front wheels, start on plumbing, keep doing fab work. For more info and pics, see the link below.
wow very slick
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 04-11-2011, 01:22 AM   #337
Dinos63
chevy only
Dinos63's Avatar
Originally Posted by rocktonka View Post
i've had my 73 cj5 for over 15 years and have taken it through numerous rebuilds. We try and get it out a few times during the year, but lately it seems like we struggle to find the time.
duude i want one of those looks killer and looks like it works killer too!!
Old 04-11-2011, 11:48 PM   #338
turbostar
Great thread guys,I've only read a few of the posts but will enjoy reading all. My most unique project is a custom built semi replica of a porsche 550 spyder(the james dean car).It has a custom chassis I designed along with special design suspension. It is powered by a Northstar mid-engine in the back. The body is fiberglass and heavily modified to fit the chassis. Next big step is paint.
turbostar is offline   Reply With Quote
Old 04-12-2011, 03:55 AM   #339
A.T. RockDriller
A.T. RockDriller's Avatar
disturbinglykool...
That box caught my eye.....
How could it not....?
BTW...
chevyrestoguy
That's about the nicest fab work I've ever seen.
Tonka....
What can we say....
I usually don't get to excited over a Jeep....But wow. That sum***** sure looks like the real thing.
Awesome
Staff
Thanks for the edit/spellcheck
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 04-12-2011, 07:22 AM   #340
Liz
Catchy title goes here..
Liz's Avatar
no one touched your post, aside from yourself. If you have a concern with it, please contact me via PM. thanks
Liz is offline   Reply With Quote
Old 04-12-2011, 08:53 AM   #341
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Uh ... what I miss ?
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 04-12-2011, 08:58 AM   #342
lakeroadster
Yea, I took a double take on that too there Chief. Reading between the lines I think the discussion is based on....
S U M B I T C H
vs.
SUM*****
(Which was automatically edited by the site software, not a human moderator.. a.k.a. big brother / skynet )
lakeroadster is offline   Reply With Quote
Old 04-12-2011, 01:54 PM   #343
A.T. RockDriller
Hey Chief..
It's like Lakeroadster said....
I posted the above and when I previewed it it had been auto-edited...which I didn't understand at the time...so I thanked the editor (system in this case)
at the end of my post....
And THEN..............Liz sent me the above.
Whatever.
I sure don't mind someone helpin' keep me out of trouble.
Les Hunter
Old 04-12-2011, 02:16 PM   #344
pockets
pockets's Avatar
As soon as the truck is running I'm going to restore my wife's 67 VW Beetle. Its been sitting for 20-something years and is in bad shape, but her daddy built it for her and gave it to her for her 16th birthday, so fixing rather than buying a different vw will be the goal. besides, I'm getting a welder soon and that will be my practice project
After that I have a 63 nova that I am dying to build. The plan is a twin turbo 496 BBC, 10pt cage, front clip, big-and-littles, etc.
Project Bad Karma
pockets is offline   Reply With Quote
Old 04-12-2011, 05:33 PM   #345
scotts62
One day...
scotts62's Avatar
Thats cool, any pics?
Scott
93 crew cab build
Project 62
Old 04-12-2011, 05:58 PM   #346
65panelrat
65panelrat's Avatar
My other ol' Bowties!
Bowties For Life!🇺🇸
65panelrat is offline   Reply With Quote
Old 04-12-2011, 08:52 PM   #347
waybad
waybad's Avatar
72 Vega GT getting a 99 ls1/2004r Don Hardy 12blt
waybad is offline   Reply With Quote
Old 04-13-2011, 03:26 PM   #348
mudderphil
this is my 54 drag car im building once its done then the pickup
mudderphil is offline   Reply With Quote
Old 04-13-2011, 07:27 PM   #349
blackedoutharley
I have had this for years... and I haven't touched it in years, LOL
And the wife's car... she bought this the month after she turned 16(which was a very long time ago!) and until 10 years ago was the only car she had ever owned. I painted it, did the interior and installed a new engine (all several years ago). I need to finish the suspension and the A/C. Now it sits in the garage covered because she is afraid somebody is going to scratch it.
blackedoutharley is offline   Reply With Quote
Old 04-13-2011, 08:09 PM   #350
texas56
texas56's Avatar
We have a bunch of them going but here is a few
1969 Camoro- Detroit Speed Mini tubs, 4 linked, 454 etc
1931 Model A Truck
1986 SWB
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
