#76 |
Re: MY little Project....
I see why it sets up so high its resting on your exhaust
![]() lol I hardly doubt it
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
#77 |
hey I was just looking at 502's build and got thinking about your springs when I spoted this picture
![]() then yours ![]() your front spring eye dosnt look as if its up as high as your and the arc almost looks tighter (I'm guessing that how I want to explane it) or maybe I'm just seeing things but I see your shocks are both to the front as were mine and 502's have one going each way
#78 |
What he means is when you took that many leaf out and you lowered it. Did you check you pinion angle? Better check before you start blowin u joints. You use a wedge to correct this, which is the easy way.
#79 | |
C35 Crew Dually
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
#80 |
C35 Crew Dually
oh ok i'll take it to the spring shop and have them look at it of can i do this from home?
#81 |
if your pinon angle is bad enough to tare up u joints you'd feel the vibration I've got a 4/4 drop on my crew cab and no shims for the pinon and I havent had a problem
#82 |
C35 Crew Dually
i'm thinking it's my carrier bearing it looks to be in bad shape.
#83 |
Shims can be bought here
http://www.stylintrucks.com/parts/pi...0114_3354.aspx Posted via Mobile Device
-------------------------------------------------------- 1984 CC Dually - 454 - TH400 - Western Hauler Edition Big plans are coming! My build thread HERE |
#84 | |
![]() Posted via Mobile Device
#85 | |
C35 Crew Dually
#86 |
[><]Sofa King Dirty 4x4[><]
How much drop is this? looks damn good cant wait for updated pics
00' Chevy Silverado 1500 z71 33"s 3" lift 5-speed Past trucks 85' Chevy C10 Step side 388 stroker 33" bfg a/t's holley 670cfm world product heads 14.80@92mph 92' S10/Tahoe sbc swap |
#87 |
C35 Crew Dually
it's about 5 in the front and 4 in the rear.
#88 |
You replace that spring pack and you will gain another 2" easy!
#89 |
C35 Crew Dually
lol yeah prob!
#90 |
C35 Crew Dually
Got a new updated list to tackle:
-Put a new hangger breaing -Fix gas tank (new sending unit) -hitch -fix the Hydro boost (it's leaking some where might throw a new steering box also.) -fix leaky valve cover -fix leaky oil pan -fix oil press guge -fix dash lights (they majically all came back on while driving?) -Get stock C35 rear leaf packs (has old tow truck ones raises the back up about 2 inches more than it should be) -mabye while the motors apart paint and clean it up a little. Think thats it.
#91 | |
#92 |
Second Chance Program
Hate it when i miss stuff like this for so long! Looks like a cool project!
#93 |
C35 Crew Dually
for most of the motor stuff (seals an stuff) i kinda want to pull the motor but on the other hand i don't lol. Hmmmm what to do.
#94 | |
C35 Crew Dually
#95 |
Grandpa in the rustmobile...
Heck of a truck! I like it!!!!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#96 |
C35 Crew Dually
#97 |
C35 Crew Dually
So been thinking about lowering my truck MORE! was thinking of doing a flip and 3 inch coils. because with my spring pack i think i can get away with it worst coes to worse move my shackle and hanger set to 1 inch? any thoughts?
#98 |
def go lower man...quit foolin with springs and shackles and start bagging it!! lol.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#99 |
C35 Crew Dually
Would love too but i have no idea where to start or how to go about it
#100 | |
-------------------------------------------------------- 1984 CC Dually - 454 - TH400 - Western Hauler Edition Big plans are coming! My build thread HERE Last edited by N2TRUX; 07-11-2012 at 11:05 AM. |
| Bookmarks |
