Building Dreams out of Dimes!
Re: Behind Taillight Gas filler drawings... Will it work?
Well guys I finally got finished cutting, bending, adusting, grinding, etc and got the filler hose installed.
Here is where my fuel filler neck will be. ![]() I had to cut a 3" hole beside the existing hole with a whole saw. Basically you just cut the 3" hole as far over as you can without getting into the side support. ![]() I also had to grind some of the bottom of the bed off inorder for the fuel hose to make a straight shot to my fuel cell. ![]() ![]() I also had to cut roughly 4 inches off of my filler hose and then bent it where it needed to be. (3" whole saw also shown) ![]() If this idea works I will do a full right up on all the tools and parts needed to complete this task. Hope it works! Thanks for your support guys! Last edited by Hazieview; 04-11-2011 at 09:47 PM. |
Looks like it might be quite difficult to unscrew the cap with the limited finger space. Thought about using a "permacap" ?http://www.kleenwheels.com/about_permacap.htm
There really is a little more room than the picture reveals. I do agree that the cap u posted would be easier. Unfortunately it won't work with the filler neck I'm using. Wish I could though.
Posted via Mobile Device |
Probably would be worth the effort and money to get a filler neck that would accept the fixed cap. Then you can position it a little lower to allow better installation of the gas pump nozzle when refueling.
Other wise you'll be kicking yourself at every fill up. Last edited by lakeroadster; 04-12-2011 at 10:46 AM. |
#5 | |
![]() I agree though for sure. I dropped the filler as far down as I could using hose I did. Still may be a problem filling up. Oh well I tried. Posted via Mobile Device |
