1972 K20
![]() Join Date: Apr 2008
I am ready to instal my new floor and tank carpet. What is the right way to make the tank carpet stay put?
I have not taken the carpet out of the box yet but my inital plan was to install the cardboard tank cover and glue the carpet to that. Can anyone give some tips on doing it the right way? Thanks in advance for your replies |
Active Member
![]() Join Date: Oct 2002
Re: Gas Tank Carpet with or without the tank cover
Good question budman k20, I whould like to know this also.
Can someone out there with the original set up please post pics. |
trucks72
If you want to do it original. It was screwed to the panel below the rear window. Most people glue the cardboard to the tank then glur the carpet to the cardboard. Gives it a smoother finish to the carpet if done that way. Then at the top you can fold it over the top of the cardboard and you will not see a edge. Most of the new gas tank carpets have clips across the top to go over the cardboard. If you use these you will sometimes see the edge of the carpet. So I will raise the carpet a little higher and fold it over the cardboard then push it back under the lip so it fits tight. Hope this is understandable. I do not have a picture at this time of it.
#4 | |
That's a good way to do it or use a crimp on windlace in a contrasting color or a matching color. Bring the carpet up flush with the top of the cardboard backer then crimp this over the top of the raw edge. |
#5 | |
I'm going to follow this Thread as I'm about to order Tank Carpet too, and would like to hear more about the Installation and pictures of the finished project!
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
![]() Join Date: Feb 2008
Does anyone use the tank carpet with bench seat to help with sound supression and clean up the look at the rear edge of the seat, or is this only a bucket seat thing?
What was the factory treatment for bench seat trucks for the tank? Cardboard tank cover or on driver's side should you be able to see the tank? Been thinking of getting the cardboard and carpet to clean up the look. Not sure about spending my money on that though. If I go this route I need the info in this thread. Thanks. |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Bill72, the bench seat trucks came with the cardboard, and the original bucket seat trucks had the carpet screwed into the backside of the cab with special clips. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
So since I replaced my Bench seat with aftermarket Bucket seats, it looks as though the consensus is to get BOTH the Cardboard and then install the Carpet over that.
My question is, how does the cardboard Instal/Stay in place?
My son installed carpet in his 69 GMC using velcro strips to hold the carpet to the back wall. The carpet that we got for it conforms to the the area quite nicely. No cardboard was used. Here is a picture before the buckets were installed.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
#10 | |
My Gas Tank is "In The Cab". The picture above looks like there is no gas tank, (but just the Rear Cab Wall). I was wondering if the cardboard goes OVER the Tank and THEN the Carpet kit gets attached to THAT. ![]()
Maybe I'm barking up the wrong tree.
It was my understanding that a Gas Tank Carpet Kit was to go over the Gas Tank in the Cab, so when you put Bucket Seats in, the Tank doesn't show (as much). Is that correct or is it just a Carpet Kit that goes into the Cab, AFTER you take out the Tank?
#13 | |
#14 | |
Is there actually a Gas Tank behind that Carpet?! If there is, SIGN ME UP!
#15 |
wow, thats a clean look!
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
#16 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
ttt
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#17 |
I am nearly positive that factory bucket trucks had no cardboard cover. The carpet was more or less a flat piece that attached to the back panel backwards at the bottom lip of the carpet with 12 screws and washers. Then the carpet just hung in place and sort of just covered the tank.
Most of the new carpet kits for the tanks are nothing like the original carpets, they are more preformed to cover the tank. I would think they were meant to be used without the cardboard cover as they seem to clip on the top of the gas tank. When I put new carpet in my truck I just used a flat piece of carpet and used the original screws/washers and hung it just like the factory did. The sides are just sort of tucked in around the gas tank.
72 Cheyenne Super 80 Silverado Blazer 2wd |
#18 | |
Thanks for the pictures and detailed information! ![]()
#19 |
![]() Join Date: Feb 2001
Guys...
Trucks (at least the 69-70---I am not sure about the other years) with Buckets were the ones that had factory carpet over the gas tanks. (Not all Vendors have the factory correct gas tank carpet. My came from GMCPauls and the fit was perfect) The back of the cab has a metal strip that the carpet is screwed into. The top of the carpet is folded over. At least that is my understanding. Fine69 is working on my truck or else I would get pics for you all.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 04-12-2011 at 05:15 PM. |
#20 | |
It's only a minor addiction
Posted via Mobile Device Posted via Mobile Device
72 Blazer CST 4x4 72 Suburban K-10 72 B.B. 402 C-10 70 K-10 4 spd 1970 GMC 2500 with 24K actual miles Current project- 69 GMC swb |
