Old 04-12-2011, 03:21 PM   #1
britski
Re: Need Help....72 C10 Keeps Dying
It will eventually die again. Everytime I have managed to start it again I just take it straight home so I don't go far with it.
One of the theories that keeps coming up is the ignition coil is over heating. This would explain why it is starting after it sits. Anyone know if this is true???
britski is offline   Reply With Quote
Old 04-12-2011, 06:00 PM   #2
AirSpeed
AirSpeed's Avatar
My 69 C10 used to do that, it turned out the float had a hole in it. I tried to buy a new float but no one had one, it had a Rochester "two jet" carb. The float had actually broken apart at the seam, I took it out an soldered it back together and havent had any problems again.
It was a pain soldering the float, every time I would get it almost sealed the heat would blow out the last bit of solder, I finally submerged the lower part in water and soldered the last bit closed.
AirSpeed is offline   Reply With Quote
Old 04-12-2011, 07:22 PM   #3
68gmsee
Active Member
68gmsee's Avatar
First make absolutely sure you have good cables and connections to the starter and ground. The cable posts can get corroded internally and is not visible unless you peel back the sheathing.
Second, buy or borrow a volt meter and place it across the battery posts and with the engine idling insure you are getting at least 13 vdc or more it may read betseen 12-14.5vdc depending on battery charge.
68gmsee is offline   Reply With Quote
