What do you think of this engine?
What do you guys think of this engine?: http://www.summitracing.com/parts/MLL-BP3830CT1/
It is a crate 383 stroker with 400+ HP advertised. Would you think this is a good price for this engine? I was going to build a 383 stroker but decided to check out some crate engines as they are professionally built, and I am not a professional. I want the engine I put in my truck to have a choppy idle and I'm not sure if this one will as the cam specs are not really listed. I was thinking of putting a holley 750 double pumper on this engine if I get this engine. What would be the advantages of building my own 383 stroker? Would this be cheaper or would buying a crate engine be cheaper?
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD 1998 Trans am, mostly stock with magnaflow catback My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329 |
Re: What do you think of this engine?
this is the motor i want to put in my truck when i get the funds. it's a solid motor and has a very good warranty. look up some videos of it on youtube, it has a pretty nice idle
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
I tried to find some on youtube, but couldn't find any
![]() Also, does anyone know if these engines can come with a roller cam instead of a flat-tappet?
GM Parts Guy
Hopefully this is what you were looking for. Not quite a square, but it gets the job done.
1975 Chevrolet C-10 Custom Deluxe (DD/WIP) 1989 Chevrolet C1500 reg cab stepside (Winter Truck) 1977 Harley Davidson XLH 1000 (Summer Cruiser) |
Getcha Pull
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
roller cam version
http://www.summitracing.com/parts/MLL-BP3833CTC1/
Quite a bit more expensive :P
yes, but thats also the fully dressed version.
![]() Join Date: Jul 2010
Tha full dressed one has a 750 eddy..unless you know carbs..i'd leave tha DP on tha store shelf
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse Last edited by Pop's C-10; 04-12-2011 at 09:20 PM. |
Summit has decent prices. Building it yourself would probably be cheaper, but then it is a lot of labor, requires a decent amount of tools, and doesn't come with a warranty... If you've never built an engine it is a lot of fun and very rewarding, but it is a learning process as well.
