Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 04-14-2011, 02:34 PM   #1
LakeMtn
Degreaser
The engine compartment on my daily driver '72 K20 is getting a little nasty. Has anyone here had good results with a degreaser that won't harm the paint?
LakeMtn is offline   Reply With Quote
Old 04-14-2011, 02:40 PM   #2
rcrahn
rcrahn's Avatar
Re: Degreaser
Take it from me do not use that purple crap degreaser from walmart. It is nasty and will damage any aluminum parts in the bay. I tried some on my 280Z engine and it looked horrible when it was over.
Best thing to do is give it a good steam cleaning top and bottom. Might cost $50 but you will be amazed....
rcrahn is offline   Reply With Quote
Old 04-14-2011, 03:36 PM   #3
Torrey72
Rollin in my K5 toaster
Torrey72's Avatar
Re: Degreaser
I like Super Clean for cleaning engines. I would drive to a self serve car wash and hose down a hot engine with it. Let it work for a minute or two. Then use the pressure washer to blast it clean. I’m not sure if it will tarnish aluminum or not? Most caustic cleaners will.
Torrey72 is offline   Reply With Quote
Old 04-14-2011, 08:49 PM   #4
2003 silverado
2003 silverado's Avatar
Re: Degreaser
Oven Cleaner Foamy type
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
Old 04-14-2011, 10:37 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Re: Degreaser
Simple green works fantastic and will not harm the paint.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-15-2011, 12:08 AM   #6
treveiger
treveiger's Avatar
Re: Degreaser
Not to steal the thread but how do you go about cleaning a engine. Wont hitting it with a pressure washer hurt it or be bad for it?
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 04-15-2011, 02:39 AM   #7
Torrey72
Torrey72's Avatar
Re: Degreaser
Using a pressure washer is just fine. Just be careful what you blast directly. I keep the engine running and work around the Cap, Alt, Air intake, and or fuse/computer box if it has one under the hood. Engines are designed to get wet. But they don’t like to drink it.
Old 04-15-2011, 06:58 AM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Degreaser
That's what I used on the motor and suspension and it worked great! I didn't cut it with anything.
Excellent point.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-15-2011, 11:20 AM   #9
cdowns
cdowns's Avatar
Re: Degreaser
i use a biodegradeable concentrate from harbor frieght it works well and for the price it lasts long// i mix it up accoriding to directions and use an old winex bottle to spray it on with then rince down with my pressure washer
Old 04-15-2011, 12:02 PM   #10
treveiger
treveiger's Avatar
Re: Degreaser
Thanks for the tip!
Old 04-15-2011, 12:11 PM   #11
LakeMtn
Re: Degreaser
Thanks to all for your help and comments. Simple Green it is...... that's one of my projects for tomorrow.
Old 04-15-2011, 01:19 PM   #12
treveiger
treveiger's Avatar
Re: Degreaser
O welcome to the forum never saw that you just joined . Lotta good info on here!
Old 04-15-2011, 06:13 PM   #13
Torrey72
Torrey72's Avatar
Re: Degreaser
If your rig starts to run rough and crazy after you hose it down. You most likely just got water in the Dizzy Cap. This will happen sometimes when all the steam is coming off the engine. Be sure to bring a screw driver and some paper towels so you can wipe out the cap. If needed. You can blast the inside of the Dizzy Cap with WD40 too to drive out the moisture also. The WD40 will not effect anything other then drive out the water.
My Camaro has holes drilled in the cap to let out the Ions that build up in the Cap. It’s a race car thing. Don’t do it for street use. Any way. I wrap the cap and wires coming out of it the best I can with plastic grocery bags to keep the cap dry when I blast it. Sort of an umbrella deal. Just remove them as soon as you blast it.
Old 05-26-2011, 09:25 PM   #14
85silverbeast
85silverbeast's Avatar
Re: Degreaser
Simple Green works great! I use it on everything.
85silverbeast is offline   Reply With Quote
Old 05-28-2011, 11:06 PM   #15
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Degreaser
purple power will dull aluminum
dollar store oven cleaner works good too but it takes everything off be careful
steam cleaner FTW
John
1999 Toyota Tacoma 4x4
Old 05-30-2011, 01:06 PM   #16
tooter
tooter's Avatar
Re: Degreaser
Dollar store Awsome cheap an works great.
tooter is offline   Reply With Quote
Old 05-30-2011, 01:53 PM   #17
treveiger
treveiger's Avatar
Re: Degreaser
If you have a pressure washer that also heats the water thatll eat the grease away very easily also, we have one that heats up and also we run a degreasser through it at the same time to clean rugs from grease shops and they always look good.
Old 06-01-2011, 01:18 PM   #18
MOJO1963GMC
MOJO1963GMC's Avatar
Re: Degreaser
What about a spray bottle of soapy water with Dawn dishwashing soap?
MOJO1963GMC is offline   Reply With Quote
Old 06-22-2011, 01:22 AM   #19
treveiger
treveiger's Avatar
Re: Degreaser
That might work but could take awhile.
Old 06-22-2011, 10:11 AM   #20
LakeMtn
Re: Degreaser
Well before I took it down to the spray wash I experimented with different cleaners on places you can't really see. Simple Green didn't do it for me. Home Desperate sells this stuff called Greased Lightening and it worked great. I made sure I wetted down surrounding exterior paint and rinsed regularly, kept a large zip-lock bag over the dizzy. Turned out great for me. Now I'm working on the undercarriage. Fun.
