Old 04-15-2011, 11:44 AM   #1
bsmith77327
bsmith77327's Avatar
72 heater core removal?
Cound'nt find the the place to post this, but i need to replace my heater core
is the procedure here somewhere? 1st post bought a 72 lwb 350 with t/b 350
bodys staight but needs alot of small repairs and paint.I'll post pictures soon as i can. thanks for the help.
bsmith77327 is offline   Reply With Quote
Old 04-15-2011, 12:22 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 72 heater core removal?
Heater core is accessed from the engine bay. Remove the hoses, and then there are 4 or 5 nuts and bolts holding on the heater box on the passenger side of the firewall.
While you have it off, it would be a good time to buy new seals too.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-15-2011, 03:41 PM   #3
clinebarger
If its a factory A/C truck, The heater box is under the dash, & will have to be removed.
clinebarger is offline   Reply With Quote
Old 04-15-2011, 05:29 PM   #4
ERASER5
ERASER5's Avatar
Gary
If only it were that easy! The last nut/bolt is hidden under the inner fender. Drop the inner fender onto the tire to get access. This of course if the heater is non-AC.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-15-2011, 05:56 PM   #5
lil hoodlum
lil hoodlum's Avatar
I agree also. That last bolt is difficult to get to. I had to take off the passenger side front fender to get at that last bolt. It might be easier to remove the inner fender though.
Keith
lil hoodlum is offline   Reply With Quote
Old 04-15-2011, 06:48 PM   #6
GASoline71
GASoline71's Avatar
Doh! Good point, and thanks for clearing that up... I came to realize after I posted that I replaced mine when the entire front end from the firewall forward was off the truck.
Gary
Old 04-16-2011, 09:16 AM   #7
bsmith77327
it does have factory a/c, thanks for the help.great forum i'm sure i'll be
asking for help time to time.I work with backyard 88 and he has been VERY
helpful.
