Old 04-15-2011, 12:00 PM   #1
8door
Not too old to learn
Question How to paint white cab top ?
What I really need is pictures of cab tops in white.
Where are the separation lines both inside the door frame and the
back of cab ? I figure the A pillar will be painted white also.
My truck is a 68 and is solid color now so I have no reference points to go by.
I will need to add the chrome strip under rear glass, so need to see where the
color line will be.
Thanks.
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 04-15-2011, 12:54 PM   #2
mrein3
mrein3's Avatar
Re: How to paint white cab top ?
I painted the window frame white on my door. Then I simply put a tape line down even with that all the way around the back.
I didn't add the chrome strip. I was going to put a piece of trip tape over the line but so far haven't bothered.
The a-pillars I painted white too.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 04-15-2011, 01:55 PM   #3
JJanzen
JJanzen's Avatar
Here's a couple of pics of how mine was done.
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 04-15-2011, 05:18 PM   #4
burkeens
Here are some photos of my family 68 two-tone with original paint, FWIW.
burkeens is offline   Reply With Quote
Old 04-15-2011, 05:28 PM   #5
Cooper33
Cooper33's Avatar
The stock paint on my 67 is only to the drip rail, no door or A-pilar. Don't have a better / closer pic.
Brad
67 Chevy SWB stepside - http://67-72chevytrucks.com/vboard/s...d.php?t=449426
89 Ford Bronco
92 Suzuki Sidekick
94 Kawasaki Vulcan 750
06 Honda Aquatrax
Cooper33 is offline   Reply With Quote
Old 04-15-2011, 05:51 PM   #6
sameyrasmea72
sameyrasmea72's Avatar
67 was painted differently than 69-72 , not sure about 68.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 04-15-2011, 06:02 PM   #7
burkeens
A-pillar was pained same as roof on 68s.
Old 04-15-2011, 06:06 PM   #8
sameyrasmea72
Looks like a 68 was painted like the 67 with the pillar and door frame not white. I guess if you are not going for a 100 % correct truck you can paint it like the 69-72 tops.
72 Cheyenne Super
Old 04-15-2011, 06:21 PM   #9
burkeens
Not true for my original 68, at least (see above). Also check out these previous threads regarding the 68 a-pillar being roof color.
http://www.67-72chevytrucks.com/vboa...d.php?t=143327
http://67-72chevytrucks.com/vboard/s...d.php?t=346534
Old 04-15-2011, 06:41 PM   #10
sameyrasmea72
I was thinking that 68 was like 69-72, but I was going by this old 68 GMC original paint we had awhile back. I think I will just stay out of this debate.
72 Cheyenne Super
Old 04-15-2011, 08:06 PM   #11
8door
Good info from all, now I can proceed except for one more question.
The white color code ?
Old 04-15-2011, 09:19 PM   #12
burkeens
Samey,
Maybe it was different for GMCs? Or there was some of both? Anyway, I like the truck.
Old 04-15-2011, 09:49 PM   #13
71gmcburb
71gmcburb's Avatar
on my 71 GMC burb all pillers exept the d-piller witch is white look like they used the drip rail as the break
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 04-15-2011, 10:04 PM   #14
BIGBLU 72
BIGBLU 72's Avatar
i didnt paint the door frames or A pillars on mine.
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 04-16-2011, 02:22 PM   #15
ges55
BLACK SATIN
ges55's Avatar
you can look in my album if you need any more. I am a fan of white tops, too.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
Old 04-16-2011, 06:17 PM   #16
lil hoodlum
lil hoodlum's Avatar
White 521
DuPont 817-L
Rinshed-Mason A-1347
Ditzler DQE-8080
Good Luck!
Keith
lil hoodlum is online now   Reply With Quote
Old 04-16-2011, 06:28 PM   #17
8door
Thanks Keith.
