Old 04-14-2011, 08:23 PM   #1
79bonanza
250 timing mark
can someone show me a pic of a I6 250 ignition timing mark with the numbers on it. i tuned my whole truck up and rebuilt my carb and i can get it to run just right because i cant make out the numbers on the timing tab thats on the timing cover. spec says to set it at 4 degrees so if someone has theres number it would be much appericiated if you could share a pic
79bonanza is offline   Reply With Quote
Old 04-14-2011, 11:29 PM   #2
geezer#99
geezer#99's Avatar
Re: 250 timing mark
http://67-72chevytrucks.com/vboard/s...=429908&page=2
Post # 44 shows a typical timing tab. Yours might not have any numbers on it. Usually each mark is 2 degrees.
Old 04-15-2011, 03:24 PM   #3
79bonanza
Re: 250 timing mark
ok man thanks, i didnt know where zero was to go from, i was thinking it was the big notch in the tab but wasent for sure. thanks for the good info man
