Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-14-2011, 07:30 PM   #1
jus2qwk
jus2qwk's Avatar
what will it do?
so the guy who is gonna build my motor is more or less building the same motor he had in a 67-69 camaro that went 6.7..... in the 8th. knowing him Im sure it was a caged lighted up a bit mostly 99%race, street car. so the question is almost the same motor what will it do in my truck. its a 406 solid roller aluminum heads 11 to 1 compression about low 500 hp. with a richmond gear 6 speed and nitto nto5 tires. I know getting off the line will suck but any one got a guess
Corey Jones Designs
CoreyJonesDesigns on instagram
Ole Silver- 1967 stepside
http://www.hotrod.com/articles/1103c...chevrolet-c10/
http://67-72chevytrucks.com/vboard/s...d.php?t=598758
jus2qwk is offline   Reply With Quote
Old 04-14-2011, 08:53 PM   #2
Super73
Super73's Avatar
Re: what will it do?
Hard to compare with out more info on the other car. Weight and 60' info would help.
My guess, mid-high 11's..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-15-2011, 03:26 AM   #3
bigjimzlll
bigjimzlll's Avatar
It ought to be fun
Mid 11's after you figure out how to launch it...shift it and keep the tranny in it. Don't let the ET deter you though, your's sounds more of a cruiser than a drag racer.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-15-2011, 08:19 AM   #4
stich626
low 12's
that 6 spd doesn't like powershifts..
you shouldn't need 11 to 1 to get 500hp out of a 406
what heads and cam he use'n
remember the heads and cam that "he" used in his "light camaro" will not work the same in a 2 ton truck
stich626 is offline   Reply With Quote
Old 04-15-2011, 11:09 AM   #5
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Weighs some where 3700lbs stock I think.....
ET Calculators:
http://www.wallaceracing.com/et-hp-mph.php
http://www.race-cars.net/calculators/et_calculator.html
http://www.google.com/search?q=hp+et...9918eb06677aa8
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 04-15-2011, 07:56 PM   #6
Super73
Super73's Avatar
I know my old 01 SS camaro with just headers, tune, ported stock throttle mody, K&N filter, Fast toys Ram air and ported MAF ends went 12.44 @ 109 with 335rwhp and 3,600lbs with a 1.99 60'. You have a lot more power but a lot less aero. I don't see any reason it won't dip in the mid-high 11's..
Old 04-15-2011, 08:21 PM   #7
stich626
he DOESN'T have that much more power..
your hp is at the wheel; his the crank.. he might have 30-40hp on you and no aero
Old 04-16-2011, 09:50 AM   #8
jus2qwk
jus2qwk's Avatar
I really dont know that much about the camaro but the guy has been racing forever and be building 400s about as long, he had a 73 nova I think with basically stock suspension running in the 5.7 index class. but as far as my truck goes it is for sure a cruiser that I wanna take to the strip once or twice a year and be able to run a fairly good time. I would be more than happy if I could run a mid 7 in the 8th
Corey Jones Designs
Old 04-16-2011, 01:41 PM   #9
Super73
Super73's Avatar
I disagree. For example my buddies 418ci SBC made 424rwhp through a TH400, 9" with loose stall and ran 6.9x/10.8x NA with a 1.55 60' in a 63 nova wagon weighing aprox 3,000lbs with driver (He did swap to an electric water pump and powerglide after the dyno and before the ET's mentioned which I know would move rwhp numbers up). That seems somewhat comparable to the motor/car mentioned that this motor is being based on. That motor is making more than 375rwhp to go 6.7x in a 1st gen camaro. We are talking about a car that should be running 10.4-10.5 in the quarter.
I don't know about the Richmond 6 speeds, but I know the T56's rob about 15% power. If it makes > 500 crank hp, it should still be making > 425rwhp.
