Does anyone use these rims anymore?
I have a pair of rims that were on the rear of my pickup when I got it from my grandfather. He called them "split rims". They have a metal ring that goes around the outside and looks kind of like a bead lock. He said he put them on because the original rims had started to crack after his camper was on for a few years. Anyone still use these things?
SIR
Re: Does anyone use these rims anymore?
...DON'T USE UM...LOOSE UM!! you nee tubes 7 there VERY DANGERIOUS,tire stores won't even fool with them...good luck.
66long low fleet http://community.webshots.com/user/LVNR66 |
Registered Loser
Yeah, when I was going through the paperwork in the glovebox of my truck I found 2 recall notices about those rims.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
![]() Join Date: Nov 2008
Loose them Please !!!! I use to work for a tire and wheel place and was one of the only guys experienced to do them ... No one else wanted to touch them ... When you have to use spoons , a big tire hammer and a cage to inflate them , that is where it gets crazy ... I saw a guy almost loose his life when he didn't use a cage and the ring exploded off the rim , banged off a couple of things and implant itself in the wall about 15 feet up ... This guy broke into tears and I think he craped himself ... Don't miss them at all , but also a part of our trucks history ..
They call em widow makers for a reason!!
And I have four of them that I took off my GMC. Don't know what to do with them yet.
What year did chevy quit using split rings?
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
ive got em on my gmc, never knew that they were dangerous... mabe now ill be a little more motivated to find new wheels.... mine are pretty rusted where the split is too
those widow makers are insane. my old boss used to make me work with em a few years ago. i used to see them usually as 16.5's. i dont think i ever ran across em as 6 lug though. all the ones i did were 3/4 ton or semi rims. i havnt touched another one since i had a snap ring fly right out the shop door and end up half way across the parking lot
Scrapper 1
well there is one good use for them cus no body makes a small enough spare tire rim for the 1960--72 chevy trucks for the 3/4 and 1 ton trucks and they make wonderful spare tire rims But will have to look at the trailer places for that small skinny rim
![]() Join Date: Oct 2009
recommend make a hose reel for the shop... at least it's a conversation piece.
