Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-27-2011, 10:22 PM   #1
chevymotocross
chevymotocross's Avatar
Considering an s10 2.2
My current 87' silverado, is a great truck. But I'm considering taking it off my daily driver status. I was originally considering a small car, like a corolla, but I realized I am single, don't need a 5-seat, and plan on not crossing over to the car side
Seems like all the mini trucks are pretty decent. My first truck was an 87' ranger with the 2.9 v6, never had problems with it. I want a 4 cyl though for maximum fuel mileage. I don't plan on hauling much and will just use it for commuting. 4 cyl manual is what I want.
Tacoma seems like a great truck, but super over-priced! I like the old nissan hardbody trucks as well.
How is the s10 94+ with the 2.2? Reliability? Gas Mileage? Certain years to look for?
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 03-29-2011, 11:08 AM   #2
Tink
Tink's Avatar
Re: Considering an s10 2.2
I haven't heard anything horrible about them, but these are the things to look out for:
-valve cover gasket leaking
-head gasket leaking (or head crack) - only if overheating is or has been an issue.
-the fitting on the hard coolant line that wraps around the passenger side of the engine and plugs into the thermostat housing often corrodes
As far as fuel mileage, they were rated at City 23/Hwy 29
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 04-01-2011, 11:05 PM   #3
chevymotocross
Old 04-10-2011, 10:53 PM   #4
68c20lwb
68c20lwb's Avatar
I would recommend one! I have a 68 C20 I used as a DD and my 6 MPG just wasn't cutting it for my anymore. I've been around S10's a lot for a while and the 2.2 is very bullet proof if taken good care of. The issues listed above are very correct and good to look out for. I just bought a 98 S10 2.2 auto. Put a air intake on, electric fan, 180* t-stat, and cut out the cat. I got 35 highway, 22 city, and 27 combined. I drive pretty conserativly in my S10 but it pays off at the pump.
1968 C20 450hp 425ft-lbs 454/SM465 4.56's 2004 HD rims, needs paint and a 5th gear!
1969 C30 Open Road Motorhome 350/th400
1972 K10 350/350/205 Daily Driver -SOLD
68c20lwb is offline   Reply With Quote
Old 04-17-2011, 04:35 PM   #5
Gumby
Gumby's Avatar
lots of v6 guys down/upgrade to those
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
Old 04-17-2011, 09:12 PM   #6
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
I got a 98 Sonoma 2.2 5 sp and its slow as a turd haha but perfect as a dd. I would recomend one, also DONT get a auto 2.2 SLOWEST TRUCKS EVER!!!
Brandon...
"IT ONLY TAKES EVERYTHING YOU GOT!!"
Semper Fi
Chevy350V8 is offline   Reply With Quote
Old 04-18-2011, 08:56 PM   #7
ka_jd7and1
is a fungineer
ka_jd7and1's Avatar
If you take care of it, they will run for a very long time.
I have a 4cyl auto truck. It has been very good to me, I have put 85K miles on it (just rolled 100K) and have not done much other than preventative maintenance.
A couple things to look out for:
Head gasket, cracked/warped head if it overheats
Plastic radiator tanks have a tendancy to crack
TIming chains - the GM chain is the best one, aftermarket seems to cause issues
For some reason, my truck will not get out of the low 20s for mileage (doesn't matter if I granny or flat-foot it).
If I were to do it all over again, I would probably get a V6 truck, their mileage is about on par with what I get now, and it has a lot more power.
I can give you a very good site for S10s if you're interested.
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons
1978 Impala 2-door, race 350/T350 - the new race car, in progress
1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant
ka_jd7and1 is offline   Reply With Quote
