Re: 6 Lug Rear Disc with E-Brake Brackets
instead of turning down the hub why couldn't a guy open up the hole in the rotor?
don't forget guys, you'll need longer studs as the rotor is much thicker than the face of the drum. |
![]() Join Date: Jan 2011
Turning it down also adds lots more wheels to the list of wheels that will fit. I put torgue thrust 2's on mine and had to do the same thing to get the wheels to fit.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
60-66 Nut
There are a couple reasons to turn down the axle flange. One as mentioned by PGSigns, is more wheel selection. Second is if you were to machine the rotors to fit the axle flange, you would have to pay to do this every time you need a new rotor. Granted it won't be that often that you will need to replace the rotors, but just machine the axle flange and only pay once for the machine work. Also as I mentioned in my original post, I recomend upgrading to the larger and longer 1/2" wheel studs. The axle needs to be removed to do this properly, so you might as well have the register on the axle flange turned down while they are out. The rotor is only about 3/16" thicker than the drum. The need for longer wheel studs will depend on the wheels being used.
