Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-19-2011, 06:20 AM   #1
Wild83C10
Wild83C10's Avatar
Re: Those with trailing arm rear suspension
I didn't weld the whole seam, just 2" every 8-10".
softballnrd27, first thanks for your service. Not sure on the exact cost but here is what I believe everything cost:
trailing arms, used: $100
crossmember from CPP: $175-$200?
Coilover shocks: QA1 $150ea
Springs: QA1 $60
coilover mounts: chassis eng. $50
Perches: CPP $?
Adjustable Track bar: CPP $170
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 04-19-2011, 07:14 AM   #2
bigsnookmaster
bigsnookmaster's Avatar
I used QA1 coilovers mounted in front of the rear, Porterbuilt trailing arms and crossmember,and built my own panhard bar and bracket. I am thinking about changing the panhard bar to a wishbone type setup. Here's a few pics:
bigsnookmaster is offline   Reply With Quote
Old 04-19-2011, 03:31 PM   #3
xteamxtreme
xteamxtreme's Avatar
What does it cost for that porterbuild set up? and can you provide me with the website? thanks.
xteamxtreme is offline   Reply With Quote
Old 04-19-2011, 06:43 PM   #4
bigsnookmaster
I'm not sure what it costs new, I bought it off another member on the board. It's real nice stuff, and Nathan from Porterbuilt is also a member and vendor of this forum. Go to Porterbuilt streetrods.com. Nathan is also a great guy!
Old 04-19-2011, 03:30 PM   #5
xteamxtreme
[QUOTE=Wild83C10;4633192]I didn't weld the whole seam, just 2" every 8-10".
so being that i have a c20 3/4 ton, and the trailing arms have an extra plate for strength. How would you recommend welding to be done?
Old 04-19-2011, 09:42 PM   #6
Wild83C10
Wild83C10's Avatar
Is the plate on the top and bottom of the arm? If so then I wouldn't worry about doing anything else other then verifying it's not rusting out in the middle. I think the CPP trailing arm reinforcing kit is a top and bottom plate.
turbo=
