#1 | |
A guy with a truck
Re: How to: Ruin a perfectly good C10
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-20-2011 at 10:02 PM. |
A guy with a truck
Finished up the exhaust today. Had to use two more bends to get the pipes from over the axle back to the bumper. I ended up using factory holes in the shock crossmember and rear framerails to bolt the 'snapper' isolated mounts to- still need to get some longer bolts for them, as they are temp-installed with what I had on hand. All in all, it turned out decent once I got my welder settings down- I wish I could go back and re-do the forward H-pipe section and get rid of the booger welds, but, oh well, it will work
![]() The rear pieces that run parallel with the 'rails will get either turned down or kicked out towards the ends of the bumper, since I have a couple of 90* bends left, but I will decide on that when the bed goes back on and after the next big projects- bed/body work and paint ![]()
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
