Closed Thread
Old 04-21-2011, 01:59 PM   #2151
mmmBoost
Re: What did you do to your truck today!
Hung my rods and pistons last night. Oh how I hate spiral locks. They can be frustrating when your out of practice...
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline
Old 04-21-2011, 02:44 PM   #2152
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I finally started mine after sitting for 3 months..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 04-21-2011, 07:38 PM   #2153
Primered_69
Primered_69's Avatar
This last Saturday I got the engine installed in the frame.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline
Old 04-21-2011, 07:39 PM   #2154
Primered_69
Last night I Wire wheeled, primed and painted the battery box.
Old 04-21-2011, 07:49 PM   #2155
Operatorfailure
Today I called to schedule when I can go look at a new project, does that count?
Operatorfailure is offline
Old 04-21-2011, 08:01 PM   #2156
67Slider
67Slider's Avatar
Yesterday I picked up 2 new fenders and 2 floor patch panels. Today I ordered another gaggle of parts from the truckandcarshop. getting close to dropping her at the paint shop.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 04-22-2011, 01:42 AM   #2157
Jeffs70
Jeffs70's Avatar
I modified my Cross Sill so I was able to run my Filler tube up to the bed from my Fuel Cell. also I started to strip the paint from the inside and outside of the bed.
Jeffs70 is offline
Old 04-22-2011, 02:24 AM   #2158
bucketObolts
bucketObolts's Avatar
not much other than cut out some alternator brackets on one of the lasers at work. will get pictures up tomorrow
LIFESTYLES OF THE POOR & UNKNOWN
bucketObolts is offline
Old 04-22-2011, 09:31 AM   #2159
PatrickGMC70
PatrickGMC70's Avatar
Last night, I kicked the damn thing. It really pisses me off some days.
PatrickGMC70 is offline
Old 04-22-2011, 10:59 AM   #2160
67Slider
67Slider's Avatar
Cruised her to class last night. Got her up to 75 with nothing falling off! Was nice to drive her, never even turned the radio on. Just listened to the sound of my exhaust leak......
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 04-22-2011, 10:10 PM   #2161
pritch
pritch's Avatar
I got my ball joints and front brakes job finished, got her back down on her wheels. Tomorrow I'll convert over to power brakes (if it don't rain, that is) and if I have time I'll start on the rear brakes.
After all that, I do need to re-visit the front end. I used the supplied upper shock mount on the driver's side, but then as I was looking around the bolt bin for something, I found a set of much heavier duty shock mounts. In time for the right side, but now I want to replace the left side.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline
Old 04-23-2011, 12:25 AM   #2162
Jeffs70
Jeffs70's Avatar
body work on my bed
Jeffs70 is offline
Old 04-23-2011, 01:05 AM   #2163
project 67 sub
project 67 sub's Avatar
changed the oil finally
project 67 sub is offline
Old 04-23-2011, 07:35 PM   #2164
butternut1972
butternut1972's Avatar
I got the first coat of primer blocked out. cleand up the mess and the chevelle from all the dust.
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline
Old 04-23-2011, 08:34 PM   #2165
71Bowties
71Bowties's Avatar
Finished wiring in the computer on my 71GMC and adjusted the throttle cable on my 72 K10 woodhauler. Rained/snowed almost all day...
71 GMC C15 swb
71 K5 Blazer
72 K10 Woodhauler
89 Suburban
13 Duramax
71Bowties is offline
Old 04-23-2011, 09:07 PM   #2166
Keller
Keller's Avatar
Dropped in a MSD Street Fire HEI distributor!
Now she won't upshift, runs great in first gear though!
I think its a vacuum line. Didnt feel like crawling under the truck tonight.
1972 C10 Longbed 350/350
Keller is offline
Old 04-23-2011, 09:38 PM   #2167
72chevy383
Worked on my driver side inner rocker and kick panel....
72chevy383 is offline
Old 04-23-2011, 09:42 PM   #2168
72chevy383
Originally Posted by lil hoodlum View Post
Installed new dash pad from LMC. Dashpad was actually boxed and is from DashesDirect. Installed hood letters "chevrolet" and installed new drop shocks (Monroes #5752, 8.625" compressed/ 12.75" extended)
Keith
Wondering what drop you have on the front, I'm looking for some shocks for my 71 build, I have 2.5 drop spindles and stock coils.
Tom
Old 04-23-2011, 09:46 PM   #2169
99-LS1-SS
99-LS1-SS's Avatar
Pulled both fenders (inner and outer) and both doors. I'm in full strip down mode. I'll try to pull the radiator and radiator support tomorrow.
99-LS1-SS is offline
Old 04-23-2011, 09:58 PM   #2170
pritch
pritch's Avatar
I got converted over to power brakes. Woulda gone better, but I had a few set backs. I didn't know there are specific brackets for specific boosters. I wanted to use a different one than the one I ended up using.
So it ended up taking longer than I thought, so all I got done on the rears was the drums off.
I didn't make it to the parts store before they closed anyways, so I don't have the new shoes or wheel cylinder rebuild kits I need. I suppose it'll be monday before I can get them.
'68 Panel
'68 C-10
Ol' Green
pritch is offline
Old 04-24-2011, 12:03 AM   #2171
ItsRandy
ItsRandy's Avatar
Mounted my oil cooler and bent the hard lines from the cooler to the bulkhead fittings on the front crossmember. I know they are called "hard lines" but they should be called "Really, really difficult to make fit lines" or "Next time I'm using braided hose lines".
I also had to bend my panhard bar so it would clear the oil filler on my rearend housing...that was easier than the 1/2" hard lines.
ItsRandy is offline
Old 04-24-2011, 01:42 AM   #2172
tcoop68
tcoop68
tcoop68's Avatar
Sandblasted my a arms , rear end support brackets, tranny crossmember , and front suspension cross members , had time to spray all parts with epoxy primer sealer then painted both cross members the same color of the frame hot lick blue. I will paint remaining part corvette silver tomorrow , will be installing back on frame in the evenings after work. This is on my 68 S/W I am frame off building to pass on to my grandson. I will get photos on as I build.
tcoop68 is offline
Old 04-24-2011, 01:24 PM   #2173
R.L.
R.L.'s Avatar
1
I knew their was something I forgot to do this weekend!
R.L. is offline
Old 04-24-2011, 03:55 PM   #2174
67Slider
67Slider's Avatar
Finally got my speedo dialed in. Took me 3 gears at 10 bucks a pop to find the right one. Even with the gear calculator on this sight. No worries tho. Was driving the other day and could hear metal hitting metal on the bumps. Got under there and found that when I lowered her the exhaust is now hitting one of the trailing arms. I guess the power steering will wait until the new exhaust is installed.
Happy Easter.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 04-24-2011, 05:03 PM   #2175
bsteele
Finally drilled and tapped the block for the z bar. Put the motor back in. I have to make a list now for what's next.
bsteele is offline
Closed Thread
