Old 04-23-2011, 12:36 PM   #1
HERB
spindles and whith
I just finished mocking up my front suspension on my 65 sub. Control arms and drop spindles from 87 sub. Well I hung a fender and discovered that now my front end is wider than the stock rear dif. My question is, is there a way to narrow the front end back to stock whith? 1 1/2 rotors by the way. thanks.
HERB is offline   Reply With Quote
Old 04-23-2011, 03:55 PM   #2
Slow Build
Slow Build's Avatar
Re: spindles and whith
Most dropped spindles will move your wheels out 3/4" per side. CPP modular spindles only move them out 1/4" per side. I know that's not what you wanted to here since it sounds like you already have your spindles but I dont know of any other way to give more fender clearance other than narrower tires.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 04-23-2011, 09:21 PM   #3
Rich 5150 69
Rich 5150 69's Avatar
Thats the first thing ECE will tell you before you convert to disc...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-24-2011, 12:40 AM   #4
protrash64
Resistance is Futile
protrash64's Avatar
Section out your control arms.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 05-04-2011, 02:48 PM   #5
HERB
I took the spindles to the machine shop and had them move the holes for the ball joints in 3/4 inch. Problem solved everything bolted back up perfect. No more four wheel drive look. Happy but poorer now.
Old 05-04-2011, 03:30 PM   #6
Slow Build
Slow Build's Avatar
Got pictures?
Past GM Trucks:
Old 05-05-2011, 09:31 AM   #7
kieth
kieth's Avatar
OK, I had not realize that was where the width increase was, I am having the same problem u are with wheels, might look into machining it out......Thanks, Kieth
kieth is offline   Reply With Quote
Old 07-07-2011, 11:28 AM   #8
HERB
Pictures of new ball joint mounted in new holes.
Old 07-07-2011, 12:03 PM   #9
neslie
I got my disc kit from pol with 1 1/4 rotors. Do these have the same problem?
neslie is offline   Reply With Quote
Old 07-07-2011, 12:11 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
Same as all others with the exception of CPP's 2" Modular drop spindles.
Keith
Convert to disc brakes.
Old 07-07-2011, 10:46 PM   #11
oldtrux
oldtrux's Avatar
after reading this thread i ran out to the garage and started measuring lol.i have ec's drop spindles,also got there 5 bolt replacement axles.front is 64 1/2'' rear is 63 1/2.is a half inch on either side a really big deal for tires?just asking.....just to understand,lolife you are saying that originally the front was a little wider than the rear?do you know how much?
oldtrux is offline   Reply With Quote
Old 07-07-2011, 12:09 PM   #12
lolife99
lolife99's Avatar
It was always wider in stock drum brake form.
The disc brake/drop spindle combo make it worse.
Porterbuilt Fabrication sells 1" narrower tubular a-arms.
CPP sells a 2" Modular drop spindle that will bring you back close to your drum brake width.
Keith
