Re: freeze plug issues
Brass or steel, I have used both with good luck. Make sure the hole is cleaned up with some emmery cloth or sand paper as well as a light scuff on the plug. Use the green loctite on the plug and drive it in with a socket that fits just inside the "lip". Let it cure and it should hold. Personally I have never had a problem doing it this way.
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
